| diyAudio Sponsor | ||
ooooo
![]() ![]() SOS-HELP-AIDE-HILFE on " DAC dilema" Hello, new here and a tech advise needed for dilema on a tube DAC on my learning table. I'm not technician, but I really enjoy play as tech on the basics, learning first, then to the table. I have an California Audio Labs Tempest tube cd player (first edition,single chassis). The problem is in the tube dac board, on left channel 2 parallel resistors # R114 & R115(1.5k 4w each value) instant overheating(really hot) after ON and no output sound. I inverted resistors from left channel to right channel and problem still on left channel and tested out board both channel resistors and all measure 1.5k ohms, but installed the ones for left ch measure 6.750R instead 7.500R The problen go after unit left for 2 days ON, and next time no sound and found the overheating resistors. Looking what it is causing that overheating, I change new tubes and most electrolytic capacitors and nothing change. Revised carefully the rest capacitors for posible leak sign.Transformer and Bridge Rectifier measured that are OK. So that my " DAC dilema"- SOS-HELP-AIDE-HILFE Thank you in advance for any posible diagnostic. Iincluded 2 photos of the board. Last edited by kkstereo; 5th February 2012 at 02:24 AM. |
| SOS... problems with Lehmann BCL ("Lovely Cube")... | Miky2011 | Solid State | 2 | 31st October 2011 10:53 PM |
| Modern PC DAC vs "Audiophile DAC" | TheLaw117 | PC Based | 140 | 17th September 2011 04:24 PM |
| The DAC "do you have experience with this dac", Best diy dac for the money? | murphythecat8 | Construction Tips | 7 | 23rd August 2011 05:08 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Page generated in 0.05929 seconds (73.81% PHP - 26.19% MySQL) with 10 queries |
