| diyAudio Sponsor | ||
help! i just recently acquired an old tube amp with 1x 6bq5 power tube and 1x 6x4 rectifier and 1x 6av6 preamp tube. it is all hand wired and i dont know where to start! i plugged it in when i first brought it home and there was sound, but it was very quiet (my hollow body electric was a little louder) and i was wondering if anyone here could help me with this. thanks in advance
-Austin |
#2 |
Greetings from FixitLand!
And welcome to the fun world of tube amplifiers! What you have could be the beginning of a nice little amp for guitar, but as it is, it does not have enough amplification (that's why it was very quiet). The 6AV6 "preamp tube" is a voltage amplifier and the 6BQ5 power tube (class A single-ended) drives the speaker. Straightforward. But a guitar produces a very low-level signal (much like a microphone). Your amp was probably intended to work with a ceramic- or crystal-cartridge phono cartridge, or perhaps a tape player, all of which provide a higher-level signal. To make this rig a guitar amp, you'll need at least one more stage of amplification. The 6AV6 single-triode (plus two unused diodes) can be changed out for a 12AX7 twin triode which would give you that extra stage. That would require replacing the 7-pin 6AV6 socket with a 9-pin socket to accommodate the 12AX7. I would suggest looking for basic guitar-amplifier schematics (I'm a hi-fi guy, not a guitarist). You'll also need to gain some basic electronic skills such as reading schematics, soldering, learning about tubes, resistors, capacitors and other components, etc. Doesn't need a college degree, but you don't want to just go in and cut wires without knowing what you're doing. Please keep us informed as you proceed with this project! Take care, -- J. E. Knox "The Victor Freak" |
#3 | |
thanks for putting the time into helping me with this -Austin |
| im new to repairing guitar amps | cutter5362 | Instruments and Amps | 5 | 22nd December 2011 07:09 AM |
| ok maybe im just a newb when it comes to amps but... | coreythompsonhm | Tubes / Valves | 2 | 3rd March 2011 02:02 PM |
| EU AMP Ecodesign Working Plan 2009-2011 - No way for new Class A - AB - H & Tube Amps | qsa | Solid State | 0 | 4th May 2010 07:47 AM |
| WTB non-working Acoustat X, Monitor or Beveridge DD tube amps. | DaveG | Swap Meet | 0 | 16th June 2009 11:56 PM |
| Someone working on an insane tube project? | DJNUBZ | Tubes / Valves | 3 | 20th January 2006 02:25 AM |
| Page generated in 0.09491 seconds (76.60% PHP - 23.40% MySQL) with 10 queries |
