| diyAudio Sponsor | ||
#31 |
Evenharmonics;
ears hear differently than microphones. Where microphones hear boosts and cuts on frequency response, ears hear reflections and diffused reverberation of still the same sound. That's why Denon Audissey makes sound much better than other equalizers that try to compensate variations caused by microphone position.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#32 |
Lynn Olson did a lot of measurements on Rectifiers when he was building his 300B amp.
The Amity, Raven, and Aurora from the page: "Moving on to the main B+ supply, I first tried a 5R4-GY rectifier (a traditional choice for 300B circuits), but was dismayed with the arc-overs and poor reliability in several examples. Maybe they were old and weak, but this sort of failure should never happen in the first place. By contrast, TV damper diodes, including the New-Old-Stock 6C*3 family and the new Svetlana 6D22S, have more-than-ample peak curves, and derating for continuous use gives more headroom in current and voltage than the traditional tube rectifiers seen in 2A3 or 300B amps. The low voltage drop (15V), huge peak currents (2A), and slow warm-ups (30 seconds) are just additional bonuses. Matt Kamna also demonstrated a technique for zooming in on the waveform on the power-transformer secondary (about 10V/div on the scope screen). The rough appearance around the zero-crossing was very obvious with solid-state diodes. HEXFRED's gave a small improvement, but conventional tube rectifiers looked much smoother, and the TV damper diodes were by far the smoothest of all. So even in low-current preamp applications, TV damper diodes give the least noise. I know from experience in the Tektronix Spectrum Analyzer division that it's much easier to eliminate noise at the source than filter it afterward. If there was an even quieter device, I'd use that, but as far as I know, TV damper diodes are the quietest from the viewpoint of switching noise. Considering that the main B+ supply is switching five hundred volts, this is not a small consideration, since switch-noise is radiated in all directions, into the B+ supply, the interior of the chassis, and back into the power cord." The page is a good read. |
#33 |
If you do not use double blind A-B testing methods it is impossible to tell the difference. The time you take to change rectifiers is far longer than the brain's ability to "remember" the slight sonic differences.
The double blind testing method has been proved time and time again |
#34 |
#35 | |
The batteries are capacitors at the end of the day...would you like to hear lead acid or nickle metal or etc ...or do you bypass the batteries with a cap what kind of cap....it goes on.. Regards M. Gregg
What is the sound of one hand clapping? |
#36 | |
Regards M. Gregg
#37 |
That's why Denon Audissey makes sound much better than other equalizers that try to compensate variations caused by microphone position Well, that not correct. Dennon has a very user friendly product however it is not one of the premier products on the market. Ever checked the EQ after using a product like Denon? |
#38 |
Rectifiers..
SS type UF, UF soft recovery, Hex<<probably the best of the bunch.. Compared to tube rectifiers..isn't it interesting how some manufacturers will pay good money to fit a tube rectifier rather than 4 SS diodes are they mad or.... Regards M. Gregg
#39 |
Kind of curious here ....some seem to think that rectifiers all sound the same therefore do all caps and all resistors likewise sound the same? Maybe since we have moved our heads 1/8 from the listening position that if we could duplicate the same listening position then there would be no difference in the sound between different caps either.
#40 |
I suppose,
It depends on what you like...Old sound...Old caps, old resistors.. Why can't cheap HIFI sound like a good HIFI?? If the components are cheaper and better...I don't believe that they design it to be rubbish..they would have a world beating product.. So back to rectifiers...if nothing makes a difference (buy cheap parts) we are all kidding ourselves because you don't need an o/p Tx to get tube sound with SS do you? Because something would have to be distorted to have a difference between one and the other.. Regards M. Gregg
| Tube rectifiers | razorrick1293 | Tubes / Valves | 14 | 11th July 2011 07:34 PM |
| Small (Novel) Tube Rectifiers? | Kashmire | Tubes / Valves | 29 | 7th May 2010 03:27 AM |
| Tube rectifiers for Dummies | bigjppop | Tubes / Valves | 8 | 17th July 2009 06:04 AM |
| Rectifiers: Tube vs Solid state.. | cathode_leak | Tubes / Valves | 26 | 13th May 2005 12:45 AM |
| Tube rectifiers | NickC | Tubes / Valves | 32 | 7th November 2002 09:10 PM |
| Page generated in 0.12204 seconds (78.60% PHP - 21.40% MySQL) with 11 queries |
