| diyAudio Sponsor | ||
#21 |
If you've got an unstable circuit, what's the issue with putting a couple of 5 cent resistors in? Far cheaper than changing potentiometers and far more effective.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#22 |
#23 |
1k is a safe value. Carbon comp are the traditional choices. The important thing is to have the resistor body as tightly close to the grid pin as possible.
#24 |
The fact that it oscillates at zero volume confirms that a grid stopper will cure it. At present your volume pot is acting as a stopper, except at zero when it is a short.
The ECC88 family has high gain up to UHF frequencies, so it sees any short piece of wire as a resonator. Combine that with the usual follower instability and you have problems. Add grid and cathode stoppers and all will be well. Personally, I wouldn't worry about carbon comp - you don't need especially low inductance as all you are trying to do is damp an oscillation by adding some resistance. |
#25 |
In a ECC88/6DJ8/E88CC/6922/6N23P/other "family members"-Cathode follower, a grid stopper is mandatory, and a cathode stopper is highly recommended - 22..47 Ohms will do nicely.
Paranoid people like me add small ferrite beads over any lead to the socket except for the shield connection, or even a small anode stopper (10..47 Ohms were mentioned as effective by Tim de Paravicini in a discussion I had with him a few years ago)... Parasitic oscillation of cathode followers is very commonplace - sometimes the only noticeable effect is a seemingly microphonic stage, as the cathode follower has effectively become a RF condenser microphone. Sometimes one gets 'buzz', 'whistle' or increased distortion - effects vary... Regards, Michael =-> |
#26 |
The heater current in EH6922 is 375mA, so they are not true E88CC clones. (Clearly EH wants us to think they are, or they wouldn't call them 6922, but rather 6DJ8 which is probably more likely what they are). I've got 100 of the EH6922s and haven't had one bad yet. I've got a handful of NOS types also, and honestly can't hear much difference. As mentioned, grid stoppers are a must.
#27 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#28 |
Another difference between ECC88 and 6922 is that the 6922 (and the E88CC) can be microphonic. The 6922 wasn't meant for audio, so it doesn't have any anti-vibration mica springs (which the ECC88 has).
So the 6922/E88CC *may* be prone to shrill or emphasized high frequencies caused by microphony. The best tube of the family is by far the E188CC, but it is expensive... |
#29 |
I don't think the ECC88 was meant for audio either, but it was meant for small signal work.
#30 | |
Single-Ended Tube Amp Kit |
| 6N1P for buffer instead of 6DJ8, 6922 | JojoD818 | Tubes / Valves | 39 | 28th April 2010 12:17 AM |
| Morgan Jones and the ECC88/6922/6DJ8 | rknize | Tubes / Valves | 75 | 18th April 2010 09:35 PM |
| 6DJ8 / 6922 tube? | nordhaven | Tubes / Valves | 25 | 27th April 2008 08:07 PM |
| WTB: New Production 6922/6dj8 Tubes | mrdon | Swap Meet | 0 | 14th October 2005 03:49 PM |
| 6922/6DJ8 headphone amp impressions.... | Morse | Headphone Systems | 9 | 6th March 2003 01:18 AM |
| Page generated in 0.09605 seconds (84.36% PHP - 15.64% MySQL) with 11 queries |
