Single ended 300b's
Single ended 300b's
Old 2nd February 2012, 02:33 PM   #1
doubtingthomas is offline doubtingthomas  United Kingdom
Default Single ended 300b's
I am puzzled, I have three amps, an AN Kit1 (8 wpc,) AN Conquests (18 wpc,) and Audion Golden Nights (10 wpc,) I have recently played them all through a passive pre-amp and to my amazement the Audion's were way the loudest at a given volume setting, next came the Conquests and finally the Kit 1. This makes no sense to me, does any one have a theory? I should add I played them all through the same speakers, Woden Vulcans with Fostex 206e's.
Old 2nd February 2012, 02:37 PM   #2
Doz is offline Doz  United Kingdom
Doz's Avatar
Input impedance?
"To err is human.. to make a real balls-up requires a computer"
Old 2nd February 2012, 03:08 PM   #3
jrenkin is offline jrenkin  United States
Are those claimed or measured watts ?
Old 2nd February 2012, 03:34 PM   #4
Alex M is offline Alex M  Europe
Doesn't the output level depend on the gain of the input and driver circuitry, for a start? Also (to a lesser extent, since all amps use the same output valves) on the OPT ratio.
Alex
Old 2nd February 2012, 03:35 PM   #5
zelgall is offline zelgall  Canada
It's the difference in input sensitivity. One amp may need 1volt for full output and another needs 2 volts for full output. As an example, I have a Leak stereo 20 that is rated at about 11 watts but only needs about .5 volts for full output and a homebrew 300b that I designed for a 5 volt input because of the preamp I was using. With the Leak a very small turn of the volume knob would be extremely loud and at the same setting, the 300b would at very low volume.
Old 2nd February 2012, 04:27 PM   #6
riccoryder is offline riccoryder
If the louder amps have more gain than needed, you might be able to get better bandwidth, lower noise, or lower distortion by changing some component values.
Single ended 300b'sHide this!Advertise here!
Single tube, Single ended, 20W, impossible? dannydanger Tubes / Valves 39 1st June 2017 08:18 PM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
Anyone play with the Zen Single-Stage Single-Ended Class A? Rino odorico Pass Labs 13 29th August 2002 09:01 AM
Single-ended Article A'af Pass Labs 0 18th November 2001 12:33 PM
Copyright ©1999-2017 diyAudio
