More power!
More power!
Old 2nd February 2012, 01:03 PM   #1
astouffer is offline astouffer  United States
astouffer's Avatar
Default More power!
For anyone who feels their current system is lacking in the power department I present this Audio Amplifiers
10KW of power and claims to be unused and hey its cheaper than an Ongaku or Wavac.
Old 2nd February 2012, 01:29 PM   #2
firechief is offline firechief  United States
firechief's Avatar
I see you found Surplus Sales of Nebraska. Cool place and wouldn't you like to wander around in their wearhouse!
"You can keep your insurance baby nothing is guaranteed" -Tom Petty
Old 2nd February 2012, 02:08 PM   #3
stoc005 is offline stoc005  United States
stoc005's Avatar
I used to frequency sweep test sonar transducers using a multi-kilowatt audio amp like that one.
Old 2nd February 2012, 04:56 PM   #4
kevinkr's Avatar
More power!
Just what I need for a subwoofer amp.. I did note that the amount of space it requires is more than that occupied by a fairly large walk in closet, and it weighs over a ton too, so I suppose not..
10kW solid state gradient amplifiers that fit in less than 12U for rack mounting are sometimes available and would be well suited to anything this could be used for.
I suspect the best place for this item would be a museum somewhere.
I've always thought Surplus Sales of Nebraska was a bit overpriced (I live in the land of the MIT Flea) but has much cool stuff.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 2nd February 2012, 05:20 PM   #5
astouffer's Avatar
Some of their prices are way out there and some are pretty good. I wonder how they sell those odd military items that can only be used for one specific thing. Like these aircraft fans Fans & Blowers: 400 Hz Aircraft Blowers
Sure that Axivane Fan is listed for a fraction of what it cost uncle sam but who is going to buy it? Don't even look at their transformer prices.
Their tube price lists used to have 7027s listed really cheap, like way under what anyone else sold them for. Always thought about buying some and then reselling on ebay...
Old 2nd February 2012, 06:05 PM   #6
HollowState is offline HollowState  United States
HollowState's Avatar
Robert Grinnell is one of the worst shysters in the business. Personal experience.
Old 2nd February 2012, 06:49 PM   #7
riccoryder is offline riccoryder
Well maybe some of us can try solar power systems with inverters that run at 400 Hz. Then we could use smaller power transformers and caps, strange surplus bargains, and out homemade curve tracers could have a faster refresh rate. That huge amp got me thinking. I was looking at some big transmitting tubes a while back that could handle 40 Amperes anode current. A couple in series push-pull would make quite a killer but very simple OTL amp. The thing about filament current of hundreds of Amperes put me off a bit though, and no three phase power here either. And there's the matter of tougher speakers...and ears.
Old 4th February 2012, 06:56 PM   #8
Austin Translation is offline Austin Translation  United States
Austin Translation's Avatar
Send a message via MSN to Austin Translation More power!
I bet you could run the fan/blower from that big amp fed a 400hz sine wave. It may run fine at 60hz just slower tho...
More power!Hide this!Advertise here!
DIY Audio Alchemy Power Station 2 Power supply PSU with case roscoeiii Swap Meet 2 29th May 2010 06:51 PM
TA8259H Max Power 37W BTLx4CH audio power IC for sale winkison Swap Meet 0 10th July 2008 09:42 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 05:49 PM
High Freq. AC Power for Filaments of 300B SE Power Amp? snoopyma Tubes / Valves 6 3rd January 2004 06:21 PM
