How the magnetic affect the sound of tube amplifier
Old 2nd February 2012, 01:28 PM   #1
siliconray is offline siliconray  China
Default How the magnetic affect the sound of tube amplifier
Today we receive a lot of thulium magnetic for a researching project (they are super strong magnetic!). The EL-34 PP amp came into my eyes when we were discussing about the project. A strange idea came into my brain suddenly: the magentic can affect the moving path of electron, and the tube is working based on electron emitting and moving, so how will the magnetic affect the tube amplifiers?
I decided to give a try. I have 3 tube amplifiers in the office: a EL34 PP amp, a 12ax7+6N1 tube headphone amp and a 6F3 3W small SE amp. After power on them for a few minutes, I put a magnetic close to the tubes and wave it. There's nothing happen when wave near EL34. But when put the magnetic close to the preamp tube 6N2 of EL34 PP, clear "pop" sound can be heard in the speaker. Then I tried with headphone amp and 6F3, both have clear "pop" sound when wave the magnatic near the preamp tube. But no clear sound can be heard at the power side.
I don't have time to listen how it affect the sound quality. And I don't have golden ears to distinguish the differences. But I think it's a interesting test, gurus with golden ears can try to listen to the sound quality affected by the magnetic, maybe there'll be some amazing result
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services
Chat with me
Old 2nd February 2012, 01:30 PM   #2
On Hiatus
SY's Avatar
Moving a magnet near the tube will induce a small voltage (Faraday's Law). A static magnet, unless it's ridiculously powerful, will have close to zero effect on the tube's operation.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 2nd February 2012, 01:33 PM   #3
On Hiatus
SY's Avatar
Tubes and magnetic fields
http://www.diyaudio.com/forums/tubes...bes-works.html
Old 2nd February 2012, 01:40 PM   #4
M Gregg is offline M Gregg  England
I can't resist..put a magnet by a CRT and thats it folkes..LOL
Degaussing in progress and no picture...LMAO
M. Gregg
Old 2nd February 2012, 01:46 PM   #5
While I think about it,
put one by a magic eye tube and thats it as well the electron flow will be stuffed..unless you can demagnetise it.. the display will be distorted..
Its good fun though if you don't mind wrecking an EM80 etc..watch the display twist as the electrons are pulled and pushed about..
M. Gregg
Old 2nd February 2012, 01:52 PM   #6
Well, if the magnetic can distortion the cateye, it must have some effect on the performance of other tubes. I know the electron beam is enclosed in a small metal enclosure, but there will be effects, more or less. I think some one can find the differences, becuase some declare they can find the difference between 2 power supply cables...
Chat with me
Old 2nd February 2012, 01:52 PM   #7
godfrey is offline godfrey  South Africa
What are the grid wires made of? If they're magnetic a strong magnet could move them, possibly causing them to touch the cathode. That would cause an audible "pop".
Old 2nd February 2012, 01:59 PM   #8
I believe the audiable pop is not caused by the reason you mentioned. if grid and cathod are short, it won't be slight pop, maybe bomb
Chat with me
Old 2nd February 2012, 02:03 PM   #9
DF96 is offline DF96  England
A static magnetic field will bend a beam of electrons - that is how a TV CRT works. It won't make much difference to a triode, because all the electrons end up at the anode eventually.
I can just see the next 'audiofool' trend! Take a 5 dollar magnet, put it in a 2 dollar ceramic case, and charge people 95 dollars for a "static field audio enhancer".
Old 2nd February 2012, 02:08 PM   #10
Ohhh can I have one..LMAO
Scan coil degauss chassis unit 10$ a pop return every 6 weeks works even better on non ferrous chassis...LOL
M. Gregg
How the magnetic affect the sound of tube amplifierHide this!Advertise here!
Can a power cord affect sound quality?? sully Parts 193 14th November 2013 11:13 PM
Does Voice Coil Affect Magnetic circuit? kelticwizard Multi-Way 28 13th October 2007 02:12 AM
solution to those who say that LED's affect the sound adversely elizard Everything Else 59 13th March 2006 06:48 AM
does the resistor's ppm affect the sound? mekanoplastik Parts 9 4th June 2003 05:21 AM
Copyright ©1999-2017 diyAudio
