| diyAudio Sponsor | ||
The attached drawing is from an Altec 6L6GC puch pull amp. Notice the .0015uf 1600V capacitor between the OT primary leads; between pin 3 of each power tube? I can't recall seeing that in another design. What is the reason for or benefit from that cap?
Well that is a pretty small drawing. Here is a LINK to the full scale drawing. Last edited by Captn Dave; 2nd February 2012 at 01:39 AM. |
#2 |
This capacitor reminds me of the old buffer capacitor that was used across the secondary of the old car radio vibrator HV supplies. It's purpose was to reduce sparking in the vibrator points and to reduce noise from same. Extreme potiental voltage spikes were buffered out which reduced wear and tear on the rectifier (0Z4) and transformer insulation. I suspect something similar is being done here. (Excluding the vibrator of course)
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
The cap could just be a crude brute force killing off of the top HF end to preserve global neg. feedback stability. Ie, dominant pole roll-off before the OT's nasty double pole roll-off.
Ohms Law V = I R |
| Philips CD880 / CDD882 oddity | xtofhuygens | Digital Source | 3 | 20th December 2011 12:34 PM |
| AVO VCM163 oddity | mobyd | Tubes / Valves | 1 | 2nd April 2010 10:59 PM |
| DN2540N5 current rating oddity | woody | Solid State | 4 | 23rd October 2009 09:04 AM |
| Oddity with NAD 3020A | GlidingDutchman | Solid State | 10 | 1st July 2009 12:23 PM |
| P-P resistance oddity | Carlp | Tubes / Valves | 6 | 30th October 2006 02:49 AM |
| Page generated in 0.07967 seconds (69.59% PHP - 30.41% MySQL) with 11 queries |
