diyAudio Sponsor
Old 3rd February 2012, 08:19 PM   #21
Jebem is offline Jebem  Portugal
Jebem's Avatar
I'm glad You found the problem.
That vibrating bells are a common problem with so many less than optimal transformer designs.
The magnetic flux must be strong, but the used E/I lamination core is not being able to restrain it inside the magnetic circuit. This is a known problem with E/I cores, but the best designs, despite more expensive, can handle it really well.
Your amplifier looks really nice and well done, why don't you ask Sowter or SJS in UK a price for a custom transformer?
My 211 Se amp is using a SJS custom made power supply transformer (500VA) and never got any problems after 10 years of good service, and believe me, it is running at about 90% of its capacity, so the design is that good.
Cheers.
Jose
If You need something done properly, do it yourself (and ask help from DIYaudio... )
One of my SE 211 tube amps: http://sites.google.com/site/sunajeb...ificador-211se
Help: Need to lose some volts Decker Chip Amps 15 7th October 2005 07:47 AM
Amp to Computer Hummmm ralph-bway Solid State 3 15th February 2005 12:46 AM
How much flux do you lose if... 454Casull Multi-Way 11 18th January 2005 09:05 PM
I could lose some heat - suggestions? 7V Tubes / Valves 11 1st February 2004 12:56 PM
Page generated in 0.08466 seconds (64.97% PHP - 35.03% MySQL) with 10 queries
