| diyAudio Sponsor | ||
I'm trying to reduce my B+ for a PP-EL84 app. I've got a raw ~323VAC on my secondary (center tap) which give 385V for the EL84. So I bought a 20W power Zener to reduce to 360V. I've connected the Zener on the center tap and I don't have any voltage drop! Across the Zener I'm getting around 9VAC. Any suggestion? ...maybe I've got a faulty multimeter... |
#2 |
Need to see diagram of that. That's not where the zenor needs to be if your discription is correct.
#3 |
If you put the zener on the center tap you would need two zeners back to back to reduce the voltage correctly.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#4 |
Uh what is the part number of the Zener? Sounds like you need some resistors to go with your zener, and it will have to be in a diferent spot, me thinks. Schematic?
"You can keep your insurance baby nothing is guaranteed" -Tom Petty |
#5 | |
The Zener should work in the CT as well as in the B+ lead, provided its polarity and the remaining wiring is correct. I assume a wiring error. Diagram please! Greetings, Andreas PS. Keep in mind that a Zener diode needs to be put in 'backwards' to operate. In the forward direction, it hasn't much of a voltage drop. |
#6 | |
Regards M. Gregg
What is the sound of one hand clapping? |
#7 |
Instead of that Zenner that will introduce additional unneeded and unwelcome noise in the circuit, I would drop the AC voltage at the secondary windings before the rectifier, by using series resistors of adequate value.
Dropping 20Volts at something like 100mA per PP channel should be easy done in this way. Try 220Ohm / 5Watt resistors to start with. Other option, and assuming that the amp uses a vacuum tube as rectifier, sometimes it is possible to replace it with an equivalent one but having a larger voltage drop (check the tube datasheets). Also, if you are using a solid state rectifier, I would replace it with a vacuum tube rectifier if one have space in the chassis, and if the transformer has a secondary winding able to cope with the extra filament current. This one fixes the excessive high voltage and will give the amplifier a better tone as well. Have fun.
If You need something done properly, do it yourself (and ask help from DIYaudio... One of my SE 211 tube amps: http://sites.google.com/site/sunajeb...ificador-211se |
#9 | |
![]() Even if Zener is double and have symmetric curve, you will add extra hum, and increase dependence of B+ from mains voltage. If it is single, you loose 0.68 volts only adding 60 Hz ripples (50 Hz in Europe) and DC bias of transformer core. Try to drop using MOSFET source follower, it is simple and filters ripples a lot.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#10 | |
...from here -> https://taweber.powweb.com/store/vdump.htm
Here is what I've done so far, from what I've read in different sources; a zener give you a constant voltage drop whatever the current load (in comparison of a resistor) ![]() Quote:
| Zener Diode Help | joesch1999 | Class D | 2 | 3rd January 2011 05:35 AM |
| zener regulator | till | Solid State | 29 | 26th March 2008 09:39 PM |
| Zener Bias | alexistheo | Tubes / Valves | 1 | 24th March 2006 02:43 AM |
| C27ph Zener - help | marijan | Parts | 3 | 26th September 2004 05:24 PM |
| No zener | ding | Pass Labs | 10 | 6th June 2001 11:11 AM |
| Page generated in 0.11369 seconds (85.10% PHP - 14.90% MySQL) with 10 queries |
