AC Heater reference to B+
Old 31st January 2012, 11:03 PM   #1
toufu is offline toufu  United States
Default AC Heater reference to B+
I am using AC for heater on my tube phono amp. How should the heater be referenced to B+? Do I have to do anything? Thanks.
Old 31st January 2012, 11:13 PM   #2
DF96 is offline DF96  England
B+ may be too high, and could exceed heater-cathode voltage limits. The heater must be referenced to something. Try ground. If this works, fine. If not, try somewhere around +40V (use a potential divider).
Old 1st February 2012, 12:20 AM   #3
Do I just take one of the ac lead and tie it to ground or +40v?
Old 1st February 2012, 12:24 AM   #4
jjman is offline jjman  United States
Yes, or use the center tap (if if exists) or make an artificial CT with 2 resistors or a pot.
Old 1st February 2012, 02:57 AM   #5
gingertube is offline gingertube  Australia
I see this used quite often (referencing the heater to a +ve voltage with respect to the cathode). Typical values I've seen are +30 to +40 Volts. I used +50V in both my latest HiFi Amp and Guitar Amp.
Last night I looked up the topic in RDH and I note that they recommended +70V.
Has anyone used this sort of "stand-off" voltage. Does that seem a bit high?
Ian
Old 1st February 2012, 03:16 AM   #6
Johan Potgieter is offline Johan Potgieter  South Africa
One can use any voltage which is safe for the lowest heater-cathode rating. I am not aware of anything less than 100V. But I am not sure of a high voltage advantage; as far as I have read, some +30V to +40V is enough to cope with any heater-cathode leakage. Only if there is e.g. a cathodyne phase splitter or Schmitt (the LTP) where a signal carrying cathode is positive, a little consideration is necessary. The 'bias' voltage can then go up to a safe 80V, so as not to leave the signal cathode (at perhaps some +100V to +120V plus peak signal voltage) too positive w.r.t. the heater.
Old 1st February 2012, 06:22 AM   #7
trobbins is offline trobbins  Australia
trobbins's Avatar
Heater-cathode leakage resistance increases with voltage away from 0V for most tubes it seems, with most change occuring by 10-15V difference. However the resistance even at 0V has been meassured for a few common valves of different ages to be pretty bloody high, and effectively negligible in terms of noticing any improvement, as the coupling is effectively swamped by heater/cathode capacitance (which is not changed by DC elevation). And if you don't bypass the DC elevation correctly then the hum/noise may get worse from ripple injection via the HV supply. It seems best initial aim is to do all standard hum reduction techniques wrt cabling, and use a humdinger pot to tune out gate/heater residual hum.
Old 1st February 2012, 10:35 AM   #8
In "Getting the most out of vacuum tubes" the author (I forget his name - you can Google) recommends +40V as giving the best life IIRC. This may or may not coincide with lowest noise/hum.
Old 1st February 2012, 10:46 AM   #9
On Hiatus
SY's Avatar
Tomer.
It's important to note that you would want that 40V (or whatever you choose) to be with respect to the cathode voltage, not ground!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 1st February 2012, 11:16 PM   #10
SY!! Don't do that ....
As SY said, but that is not always possible e.g. when max. heater-cathode voltage is 100V and a cathode sits at +120V. One then does as well as one can.
This brings me to the point that the problem is not with heater-cathode (leakage) resistance as such, but the fact that sometimes a positive cathode can pick up heater "hum" by acting like the anode of a heater-cathode diode (depending on circuit circumstances obviously). I have had a few occasions where the heater-positive state has cured hum-pickup. This is possibly a rare occurrence, but still it is easy to get the heater chain positive, just in case a rogue tube comes along acting up sometime.
AC Heater reference to B+Hide this!Advertise here!
Best AC Heater Practices Valverine Tubes / Valves 30 17th June 2015 09:23 AM
Regulated heater reference Quince Tubes / Valves 8 23rd March 2007 11:48 AM
Heater reference Nixie Tubes / Valves 3 2nd July 2006 04:58 AM
AC or DC Heater? sauuuuuce Tubes / Valves 2 27th October 2004 01:57 PM
