| diyAudio Sponsor | ||
Hi all!
I need schematics or project for Tube/Valve buffer with ECC88 or PCC88 that will be power supply Ucc=+/-25V. Thanks and cheers!
#2 |
+/-25V will give a sh-tty performance. Add a doubler on the positive side as it might work acceptable with +50V. Just check the Ua/Ia curves.
If you want a tube that works OK at low voltage you should go for 6N30. Understand from your doublethread that this is for a Gainclone project. And as someone else said, use Google. There are lots of, more or less, doubtful projects out there.
Brgds Lars |
#3 |
I hope it helps you a bit in the right direction !
Not my cup of tea but it works Audiofanatic
Be nice to animals. |
#4 | |
Eli D. |
#5 | |
Very intersting simple schematic! Ist it your project if you have crated this project interst me how they behave steam harmonics in the amplifier? Give please show graphs. You'll be very greatefu!!! |
#6 |
Hello!
It has 2 pieces PCC88 and 2 pieces LM1875 and 1 pieces toroidal transformer with the 230Vac/2x18Vac/100VA . From all this i want to i create a hybrid audio amplifier, so please give suggestions on how all of this to close the stereo amplifier. Thank you for your cooperation ! P.S. Is it can be replacet 6922 with PCC88 or ECC88? Last edited by formula 22; 15th February 2012 at 06:18 AM. |
#7 |
frugal-phile(tm)
6922 ~ 6DJ8 ~ ECC88
You can create an ~ 50-0-50 set of rails for the tube by using voltage doublers on each rail on the tube section of the XO and get much better results. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 |
Look at the Music Fidelity X10D
Thread with schemtics here: musical fidelity x10d schematic The one I traced the circuit for (posted in that thread) used 6AQ8 but usually came with ECC88. +/-24V rails in that design. Cheers, Ian Last edited by gingertube; 16th February 2012 at 05:11 AM. |
| ECC88 tube buffer NEEDED ! | vmed_cha_gr | Tubes / Valves | 25 | 14th December 2011 04:01 PM |
| Comments on 6gk5/Ecc88 Valve Phono Amp | velvetsunrise | Analogue Source | 1 | 9th January 2010 03:37 PM |
| Tube socket for ECC88, drawing | peranders | Tubes / Valves | 7 | 10th August 2009 01:59 PM |
| Valve Buffer amp | Brit01 | Tubes / Valves | 5 | 6th September 2008 09:09 PM |
| buffer stage ECC88 or ECC83? | KevinTams | Tubes / Valves | 4 | 27th August 2005 12:09 AM |
| Page generated in 0.09864 seconds (73.15% PHP - 26.85% MySQL) with 11 queries |
