Wind (Thermionic?) noise, and other strange sounds
Old 29th January 2012, 01:04 AM   #1
wicked1 is offline wicked1  United States
wicked1's Avatar
Default Wind (Thermionic?) noise, and other strange sounds
My phono (p2p aikido) started making a noise that sounds like a microphone picking up an intermittent breeze. It was one channel and I tracked it down to one of my tubes. Is that a common symptom of aging tubes?
It made another very strange sound.. The tubes are shielded. When I removed the shield on this tube it went bbbzzZZZZZzzzp. Basically, a strange buzz that increased in volume for about 2 seconds, and then decreased and stopped. I can put the shield back on, then remove it again, and every time I remove the shield it makes that 2 second long buzz.
What is that?
And last, is there any way to tell when tubes are going bad w/out a tester? I've been suspecting I'm hearing some distortion, but it's nothing major. But, I'm second guessing myself, as this hobby has ruined music for me .. I always hear distortion, and it's usually in the recording (a lot of modern music is all distorted.. entire albums sound quite bad, and a lot of old music (60's rock records) have distortion at all the loud parts) so.. maybe it's just my records.
Old 29th January 2012, 01:47 PM   #2
DF96 is offline DF96  England
Could be RF oscillation, or bad microphonics.
Old 29th January 2012, 04:47 PM   #3
Jebem is offline Jebem  Portugal
Jebem's Avatar
An excessive heater to cathode voltage differential can create these problems in one or another tube, depending on the batch quality and manufacturer. Don't trust too much the datasheets. They have been written by manufactures that want their tubes to look nice.
Assuming all was well before this issue, and as You have identified the root cause on one single tube, I would just replace it and see.
If You need something done properly, do it yourself (and ask help from DIYaudio... )
One of my SE 211 tube amps: http://sites.google.com/site/sunajeb...ificador-211se
Wind (Thermionic?) noise, and other strange soundsHide this!Advertise here!
LT108 Oscillation sounds like tube rush/white noise Hearinspace Tubes / Valves 5 31st July 2010 06:52 PM
Strange sounds when power down gainclone synthius Chip Amps 52 11th April 2008 08:58 PM
Strange noise...? Skorpio Solid State 16 6th August 2007 07:21 AM
strange noise from right channel keyser Everything Else 15 2nd May 2005 11:14 PM
Port Noise, Wind Speed................. OMNIFEX Multi-Way 20 13th April 2003 05:27 PM
Copyright ©1999-2017 diyAudio
