diyAudio Sponsor
Old 28th January 2012, 04:17 PM   #1
hrnous is offline hrnous  Czech Republic
Send a message via ICQ to hrnous Send a message via Skype™ to hrnous
Default EL34 Characteristics for Ug2 400V
Hello.. i need EL34 characteristics for draw loadline but WITH Ug2 400v(420v) AND Ug1 lines TO THE -40V or more..most of public satasheets has -Ug1 lines TO the -30 or -35V, but i want to draw loadline for -Ug1 -39V that will looks "clearly".. Bias point "line" 1mm above "zero" dont look very clearly..
THANKS
814 as Triode / Max. Ug2 voltage the_manta Tubes / Valves 0 2nd July 2011 07:36 PM
How to run RH807 at 400V? carbondated Tubes / Valves 0 23rd April 2011 09:31 PM
4,400uF / 400V RIFA WALTER BURKHARD Swap Meet 9 8th March 2007 08:16 PM
El34 PP Vs. El34 PSE alexmoose Tubes / Valves 47 6th September 2006 05:44 PM
Page generated in 0.06195 seconds (62.66% PHP - 37.34% MySQL) with 10 queries
