diyAudio Sponsor
Old 27th January 2012, 06:39 PM   #1
10west is offline 10west  New Zealand
Default Preamp Volume Controls
I've got a bit of a dunce question. I've been making the odd valve power amp since I was 13-14 (25 now). I realise that I've never made a valve pre-amp, I've got enough parts in the old parts drawer to make something I think, but I don't understand about fitting a volume control. I see alot of designs on the net for preamps that have tone controls but thats it. Am I right in thinking that I can pretty much just put a variable resistor on the line source prior to it going into a preamp circuit such as the one below?
Old 27th January 2012, 06:46 PM   #2
DF96 is offline DF96  England
A volume control is not quite a variable resistor (that would be two connections) but a potentiometer (three connections) acting as a potential divider. Just look at what other people do - there are plenty of preamp circuits on the web. Even the bad circuits usually manage to get the volume control right.
Old 27th January 2012, 07:09 PM   #3
Hi! Thanks for your help,
So What I need to be doing (using the above circuit as an exampe) is to put my potentiometer ont he input side, so the wiper feeds the input and the other two connections are connected to ground and the source signal respectively. I suppose the next question is what value pot to use.
I seem to remember reading that the ballpark figures were something along the lines of 10k for SS input or from a valve device you would use around 100k. Is is this at all valid? Or are there any simple calculations or rules you can follow to choose the correct one?
Thanks again for your help!
Old 27th January 2012, 07:36 PM   #4
Yes, you've got it. The value is not too critical. It needs to be equal to or higher than the minimum load of the source. It also needs to be less than four times the maximum source inmpedance for the next stage. If in doubt, use 50k - a bit more for valves, a bit less for SS.
You normally need a log law pot, so that it roughly matches the way our ears respond to volume changes.
Old 28th January 2012, 04:02 PM   #5
Hi-Q is offline Hi-Q  England
Hi-Q's Avatar
Interesting that your schematic of a Pentode strapped as a Triode shows both G3 and G2 connected to the plate. This is the way I always expected it to be done but appears to be frowned upon in output stages. I can only assume it is because of the higher currents expected and the more fragile G3 is returned to cathode instead. Just to keep on thread, I think that all that requires to be said on the volume control values has already been stated. I recently came across a Guitar amplifier that had 3 volume controls fed from a Tone Ladder Network and then summed together. All controls were 470k LOG which always was a standard value on older tube equipment, in fact most volume controls were either that or 1 Meg Ohm. Nowadays I find much lower values in use, more probably due to the scarcity of the higher value controls, especially in Tandem configuration. 50k LOG and up seems to be the more common.
Volume Controls KatieandDad Analogue Source 10 21st November 2011 08:38 PM
Tapped volume controls fooeywuffle Swap Meet 0 19th July 2011 05:51 PM
Volume Controls Glowin Plates Tubes / Valves 8 8th April 2011 02:42 AM
Has Anyone Tried The P&S Volume Controls? dantwomey Chip Amps 5 22nd January 2010 07:57 PM
New version volume controls polsol Parts 2 21st September 2004 12:16 PM
Page generated in 0.08715 seconds (74.72% PHP - 25.28% MySQL) with 11 queries
