diyAudio Sponsor
Old 27th January 2012, 12:22 PM   #1
Exclamation IS 6N6P A DIRECT REPLACEMENT FOR ECC88CC ?
Hi
I have a pre-amp based on two siemens e88cc tubes , one for each channel.
I was wondering if the russian 6N6P is a direct replacement.
If not what kind of tweaks should i do to make it work in the place of ecc88 ?
Old 27th January 2012, 12:42 PM   #2
There ain't a tube called ECC88CC. But there were ECC88's and E88CC's, from which the first ones were derived. The 6N6P is not even similar to one of them. The Russian equivalent to E88CC or 6922 is called 6N23P or 6N23P-EV.
Best regards!
Old 27th January 2012, 12:43 PM   #3
No, it is not a direct replacement. The pinout is the same, but the 6N6P consumes more heater current and the power transformer may not be up to it. There is also a difference in gain between the two, and optimal working points etc etc.
Best would be to provide us with a schematic of the circuit, than we can say what you could do to adapt the circuit.
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 27th January 2012, 01:20 PM   #4
I guess this is why it sounded muddy when i put it for testing. I will try to make a diagram of the circuit my pre-amp uses & post it here. Thanks
Old 28th January 2012, 08:53 AM   #5
Finally i realized that it will need a lot of modification to put the Russian ones.
Better leave it this way.
Plate loaded 6N6P over SRPP 6N6P any day of the week... Bas Horneman Tubes / Valves 14 26th February 2011 04:43 AM
Is a LM335 a direct replacement for a LM317T? phrarod Tubes / Valves 13 18th April 2010 01:30 AM
2SC2001 direct replacement / substitute samim_kp Parts 1 24th March 2010 06:00 PM
Direct (or almost direct) replacement for Morel MW144? mr_push_pull Multi-Way 1 19th April 2009 04:43 PM
Is the 6N6P a direct substitute for the 5687? Ruach Tubes / Valves 2 11th November 2005 06:37 PM
Page generated in 0.08283 seconds (72.25% PHP - 27.75% MySQL) with 10 queries
