diyAudio Sponsor
Old 27th January 2012, 03:58 AM   #1
Default Heater dillema for multi chassis phono stage.
So I'm currently working on a phono preamp, that's using 4 c3g tubes.
Originally, I was going to use a single case, but it was starting to look VERY squishy, so I'm going to gut an old preamp that I no longer use, and house the power transformers in that.
I figured an 8 pole speakon connector will suffice, wired something as follows :
1 : Safety earth
2 : HV
3 : HV (ground)
4 : Heater (6.3V)
5 : Heater (0V)
6 : 15V (voltage ref for regulator)
7 : 15V (ground)
8 : unused
What occurred to me, was that I've only got enough connections for 1 heater winding. If there is enough current (the winding is a 3A winding), can I run all four tubes of the single winding ? Each c3g uses about 0.4A, so there's plenty of overhead ...
Another question, is it better to rectify near the transformers and transfer DC, or transmit AC, and do the rectification in the main chassis ?
Old 27th January 2012, 04:44 AM   #2
grufti is offline grufti  United States
grufti's Avatar
Rectifying near the transformer is better in my experience. CCS circuits should be on the main chasis, if you use them.
Old 27th January 2012, 04:51 AM   #3
Thanks for that ...
Actually, if I rectify near the transformers, I can tie to 0V lines together, freeing up a connector for a second heater winding ...
That will make my speakon look like this :
1 : Safety earth
2 : 230V
3 : 15V
4 : 0V
5 : Heater (6.3V)
6 : Heater (0V)
7 : Heater (6.3V)
8 : Heater (0V)
I'll double up on the 0V lines in the cable itself, so the 230V and 15V lines may be twisted around a 0V line. Or would shielding the umbillical mitigate that necessity ?
Old 27th January 2012, 05:06 AM   #4
ryuji is offline ryuji  United States
twist each heater winding in the umbilical and shield the entire umbilical, you can pretty much be positive you are not picking up any RF/hum at that point
Old 27th January 2012, 05:26 AM   #5
Thanks heaps for that.
I dunno why, but making cables is crazy fun
As is making amps and preamps
Old 27th January 2012, 05:31 AM   #6
It indeed is a lot of fun. I had just finished rebuilding my 6cb6/807 based 5 channel amplifier and im already considering changing out the 807's for gu-50's i got laying around.. its certainly an addiction
Old 28th March 2012, 05:32 AM   #7
grufti's Avatar
Have you finished your amp yet? How did it turn out?
Old 28th March 2012, 05:45 AM   #8
No, I haven't sadly
I haven't been able to dedicate too much time to it. It is close to finished though.
They layout is pretty much done (for both PSU and preamp), and everything is screwed down, so what will be left to do is the actual wiring, then the testing, then the listening.
Multi input (with phono) preamp kits? captainobvious Analog Line Level 4 22nd February 2010 05:43 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
Multi chassis grounding scheme. G Tubes / Valves 13 6th November 2008 05:06 AM
100mA heater tubes for phono mashaffer Tubes / Valves 4 25th June 2008 09:54 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Page generated in 0.10364 seconds (75.08% PHP - 24.92% MySQL) with 10 queries
