| diyAudio Sponsor | ||
First the background. I replaced the coupling caps between input and driver/invertor in a pair of tube amps. Now when I turn them on, both amps come up, but after about 10minutes one amps volume decreases. Does this sound like a cold solder joint? Thanks for any help. I ask this as the amps weight around 70lbs each are a real PITA to go back into.
Evil looms. Cowboy up. Kill it. Get Paid. |
#2 |
Doesn't sound like a solder joint problem to me. It's easy to test the joint though; see if the volume still drops with test leads on either side of the suspect joint.
#3 | |
btw, remember to check your RCA connectors they can do strange things if not making proper contact dont know that much about tubes, but I guess its the same thing with tube sockets |
#4 |
If you replaced electrolytics did you put them back in the right way around ?
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#5 |
Changed out PIOs for Teflons. It happens each time I turn the amps on when they are cold. If I leave them on standby(heaters only) and turn on plates, volume is still low on one. Regards and thanks
#6 |
you might need help from tube amp forum
thread moved moderation |
#7 | |
If the problem does not change, then something else is wrong with the amp. |
#8 |
measure all your components in the circuit comparing one side to the other, and check for visible decay of resistors, joints, capacitors, etc.
If your confident you can do it safely, probe the bias point of each tube as well as anode and (if applicable) screen voltages of each tube, anything with large differences one channel vs the other is suspect. some thoughts: did you check the capacitors for proper capacitance/lack of shorts before you installed them? might want to check for excessive leakage with it turned on. the grid should measure near zero volts DC Last edited by ryuji; 27th January 2012 at 05:15 AM. |
#9 |
I think I have solved the problem. jiggling the input and one of the driver tubes seems to have cured it. I suspect either a bad tube socket or poor soldering when I changed caps (mea maxima culpa) Now to go in and solve the problem for good. My poor back! Thanks for all the help. As usual the board is a font of wisdom and knowledge. Kindest regards John Dozier I knew tubes were some trouble. These are my first tubes since rebuilding a pair of Fisher 50a's many years ago. But the sound is worth it!
| Any non Hi-Fi brand solder better than Mcap and Siltech silver solder? | mbl | Analogue Source | 23 | 24th November 2010 03:13 PM |
| Smooth Joint Connection of a Compression Driver to An OS-Horn | whgeiger | Multi-Way | 13 | 24th October 2010 01:56 PM |
| Cold solder joint? | Richard Ellis | Digital Line Level | 3 | 18th August 2009 11:43 PM |
| SMD BGA joint failure | theAnonymous1 | Parts | 8 | 22nd January 2009 06:36 PM |
| Adhesive experts: why did this joint fail? | BillEpstein | Everything Else | 12 | 8th February 2006 01:49 PM |
| Page generated in 0.10880 seconds (76.62% PHP - 23.38% MySQL) with 10 queries |
