Input Impedance/Buffers
I'm currently running a preamp that is driving 3 amps. One pair of tube monoblock amps, a 2 channel tube amp and then a plate amp that drives a subwoofer.
If I'm running the tube monoblock amps and connect the plate amp or the 2 channel tube amp I can hear a little volume drop off in the tube monoblock amps output.... I'm guessing it is just the product of the 3 amps all pulling from the same input signal....
I'm thinking of building some buffers... I was thinking it would be great to have three 2 channel buffers to isolate the signal output of the preamp to the 3 amps. I'd build 2 channel buffers just to have them be more flexable for some other use later.
I'd build them 1 at a time. for a preamp driving 3 amps with the impedance below... between a preamp and the 3 amps below... Where would the 1 buffer do the most good?
I also am finding a lot of good buffer DIY designs on this site. whats best for the buck?
My amps-
--Stereo Tube Amp - Input Impedance 270,000 ohms Input Impedance
--1 Pair 75 Watt Monoblock Tube Amps - 20,000 ohms Input Impedance
--Plate Subwoofer Amp – 22,000 ohms Input Impedance
[/U]
A bit thanks for the B1 Buffer idea.. Perhaps build that type of design into my output stage of the preamp. I was looking at the B1 builds in the Pass Labs page just a moment ago.
Looks like a lot of capacatance on the power supply. What did you use for a power transformer?
Most circuits i see only use low impedance for the input, where an attenuator is wanted. Majority of interstage circuits i have seen use 100k and 470k values.
I myself use 100k for the grid leak on fixed bias and 470k~1 meg for cathode bias
Im curious whats your up to with your setup, you got quite a variety there:
2 monoblocks, 1 stereo amp and a plate amp. i understand the stereo and the plate, or the two mono's and the plate, but what is up with having all of them?
