| diyAudio Sponsor | ||
hello to everyone
I have designed a line preamplifier with 6c19 because iwanted a litle gain. The rise is 120 v with load 2k. The cathode resistor i ve put 2k trimmer 1,5k parallel to regulate the milliamper. The best sound passes between 35-50 milliamper. The gains is sligntly below 2. I ve thougnt to make another for gain. I would like your opinion. somone bouilt something similar? sorre for the not so good English i |
#2 |
sorry 6c19 !!!
#3 |
#4 |
Ηello Takis , congratulations! , great construction !! .
#5 |
WOW
This looks nice Can you share your schematic What a nice chassis you have there did it yourself ? Thanks, Audiofanatic
Be nice to animals. |
#6 |
those pics are kinda blurry...
#10 |
Taki why you don't turn the schematic to SRPP instead of two common cathode stages , with SRPP you will have more gain and low output impedance , and you can lower the bias current too .
| tube line preamplifier circuit | korabetsni | Tubes / Valves | 16 | 18th November 2011 11:19 AM |
| FS: Dispre JFET line (headphones) preamplifier | supernet | Swap Meet | 12 | 3rd October 2011 08:59 AM |
| Compactron 6C10 & 6Q11/6K11 tube data | rsumperl | Tubes / Valves | 2 | 7th June 2011 12:56 AM |
| Line stage preamplifier | anders.a | Tubes / Valves | 16 | 26th August 2010 10:47 AM |
| Line and Headphone Preamplifier/Amplifier | Jean-Paul_2 | Headphone Systems | 4 | 11th June 2009 07:22 PM |
| Page generated in 0.10732 seconds (76.72% PHP - 23.28% MySQL) with 11 queries |
