| diyAudio Sponsor | ||
I am a looking for a schematic using some cheap output tubes (<$10) for some 7k output transformers.
transformers look like 3~5 watts SE.... power trams 550 vct and 6.3 filament |
#2 |
I've seen some single-ended 6BM8/ECL82 schematics with a 7k primary. The Japanese "super triode" ECL82 is one that springs to mind. I've not built that circuit, but I have breadboarded the "Morse's Single Ended" ECL82 schematic found on this forum using 7.5K primary and was impressed enough with the sound to commit it to a chassis.
#3 |
RH84 amp -Said to be well well liked if you google it.
RH 84 - Tube Audio ...... RH DESIGN I don't think 7K will matter much as some designs as the Decaware ZEN EL84 SE amp is another to look at uses 10K outputs. Edcor makes good bang for the $ transformers. Even the well regarded Zen uses them. Just discovered RH has preamp's in google search of rh84 amp RH 84 - Tube Audio ...... RH DESIGN Last edited by rmyauck; 24th January 2012 at 02:08 AM. |
#4 |
The usual 9W Pentodes use a 7K OPT. ECL86/PCL86 for example. But of course, a pentode can be used with nearly every OPT. EL84 etc. is also possible here.
Терпенье и труд все перетрут
#5 |
thank you all for the fast responses. Bought some iron from ebay and was looking for something easy to build.
I don't have 5 volts availble but can a 12 volt 3 amp rat shack transformer. |
#6 | |
I searched "Morse's Single Ended" with no results |
#7 |
Apologies, I thought it would be easy to find. I had the same problem relocating it as you.
Here's the schem: ![]() I'm running it triode-connected using 7.5K:8Ω OTs from an epiphone valve junior guitar amp. The little 5W OTs are more than enough iron for this little guy, and triode connected gives me exactly enough power for the speakers I want to use in a small home office environment. |
#8 |
frugal-phile(tm)
Note that Morse's amp is SE Pentodewith no feedback so is going to be a current amplifier so care needs to be taken that the loudspeakers you use are happy with current drive.
From the map i drew that andrew just posted came an RH variation using the (supposedly rare -- i have lots) ECL86. ![]() I plan to go ahead with this build, the layout below the scema is for some WE sockets i have that come with attached "tag strip". I haven't had it vetted yet, Of the greyed out bits, the bypass cap on the output tube is probably a good idea, the screen grid regulation is optional dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
Thanks again!
I am going to see if I can get rid of that big power resistor. My speakers are rated for about 100 watts max . I don't listen to stuff very loud any way......neighbors.... |
| IC: Hashimoto 20w 5K/7K Output tranformers | JoshK | Swap Meet | 9 | 30th November 2011 01:49 PM |
| repairing 5-7k amps | timwebb | Car Audio | 11 | 25th November 2010 03:14 AM |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 05:10 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| A pair of Focal Audiom 7k NOS | kasra | Swap Meet | 2 | 9th March 2006 08:05 AM |
| Page generated in 0.12374 seconds (79.98% PHP - 20.02% MySQL) with 11 queries |
