adapter to go from 6L6 to 807
Old 22nd January 2012, 11:55 AM   #1
Burnedfingers is offline Burnedfingers  United States
Default adapter to go from 6L6 to 807
hi,
Have been thinking about making an adapter so I could try 807's in my Wurlitzer 6420 mono block amps. So here is what I came up with. I would appreciate your suggestions and comments.
octal side/base to 5 pin socket
pin 1 NC
pin 2 to pin 1 on 5 pin socket
pin 3 drill hole in octal base near pin 3 of octal socket to run to plate cap
pin 4 to pin 2
pin 5 to pin 3
pin 6 nc
pin 7 to pin 5
pin 8 to pin 4
Old 22nd January 2012, 03:39 PM   #2
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
Should work out pretty good--Just watch those top-caps!
6L6 and 807 are basically the same valve, just the 807 version was made for RF duty so they shoved the plate to a top-cap....
Das Beste Oder Nichts
Old 22nd January 2012, 09:19 PM   #3
Old 22nd January 2012, 10:36 PM   #4
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
Except pin3: if go from 6L6 to 807 I would use the feature, when anode is far from filament (pin2).
The Devil is not so terrible as his math model is!
Old 23rd January 2012, 10:48 AM   #5
So, what are you saying? Don't make the adapter? Make the adapter but run the plate wire outide of the adapter?
Old 23rd January 2012, 11:20 AM   #6
trobbins is offline trobbins  Australia
trobbins's Avatar
Maybe put an anode stopper near the cap, and take the anode lead as far from other pins as possible.
Perhaps try and shield the grid interconnect, and/or include a grid stopper in the adaptor.
Old 1st May 2015, 02:20 PM   #7
reaper996 is offline reaper996  United States
OBF, how did this work out for you? I would like to do something similar in order to use some 807's in my Park Audio Chubby Clementine.
Old 2nd May 2015, 08:57 AM   #8
trobbins's Avatar
Geez you'd need a lot of spare height to want to try this adaptor!!
Also best to use a silicone high temp lead, as it will be in close proximity to the hottest part of the glass and will receive radiant heat.
Old 2nd May 2015, 11:47 AM   #9
As mentioned it was quite high so height is a consideration. It worked great. I had to try it and it worked out fine.
Old 2nd May 2015, 02:22 PM   #10
I have 20 foot ceilings, so there is room to spare
adapter to go from 6L6 to 807Hide this!Advertise here!
6L6/807 AB2 triode-- screen drive? Matt BH Tubes / Valves 2 13th October 2011 02:03 AM
What is grid resistance of 807/6l6 in pentode ryuji Tubes / Valves 9 4th May 2011 09:52 AM
G-807=807 SE or PP? gabrielbecheanu Tubes / Valves 8 18th July 2010 11:57 PM
807/350B/6L6 PP amps PSU ? coresta Tubes / Valves 7 3rd April 2008 08:20 AM
807 Amp s2kov Tubes / Valves 5 19th January 2005 12:32 PM
Copyright ©1999-2017 diyAudio
