New Tim Mellows OTL project
Old 25th August 2017, 07:00 PM   #781
victor dascalu is offline victor dascalu  Romania
Nice work, congrat.
Can you post your final schematics with balanced input?
Have you tried a CCS stage on the triode cathods?
Old 25th August 2017, 07:04 PM   #782
Originally Posted by Black Jack View Post
I think you haven`t any chance to match 33`s from batch of 10. Need 100 tubes
I preburn 33`s with heater 6-9-12 VDC for 12 hours each step.
Also I decrease bias to 50 mA in OTL and burn some hours before 100 mA and 200 mA...
Why 6-9-12 vdc and why dc ?
Old 25th August 2017, 07:29 PM   #783
Black Jack is offline Black Jack  Ukraine
It`s "training"
Because 6C33C work with 12.6 Vrms heaters in Tim Mellow`s design.
And applying standard voltage for new tube is not good.
Old 25th August 2017, 07:32 PM   #784
ok, let say trainning, but why dc instad of ac?
Old 26th August 2017, 05:23 PM   #785
No matter AC or DC for training. VAC_rms = VDC
And using 12.6 VDC the same as 12.6 VAC
Old 6th December 2017, 06:05 AM   #786
Tyimo is offline Tyimo  Hungary
Hi!
How many Vrms needs the 6C33C output stage for full output power?
Greets:
Tyimo
"Replacing any coupling capacitors with a well designed and correctly matched driver or interstage transformer yields an almost shocking improvement in sound..." Peter Qvortrup
Old 8th April 2018, 08:58 PM   #787
multi-volti is offline multi-volti  United States
multi-volti's Avatar
Does anyone know if the 6C33C-V socket reliability problems are limited to the filament/heater pins?
I mistakenly assumed the one large pin (~0.123” diameter) was the high current pin common to both filaments but datasheet indicates all 4 filament pins are separate.
I would hope & assume the heater pins are the problematic area on the sockets but may not have been paying attention to prior discussion as I wasn’t actively concerned at those times.
Thank you
Murray
Old 9th April 2018, 07:21 PM   #788
atmasphere is offline atmasphere  United States
atmasphere's Avatar
The large pin is the plate. The reliability issues are indeed related to the filaments. I don't think I've seen one of the other pins fail.
New Tim Mellows OTL projectHide this!Advertise here!
OTL designed by Tim Mellow with 4 6C33C? dwhitf Tubes / Valves 380 1st November 2017 07:46 PM
Preamp for Tim Mellow's 6C33C OTL flanagan Tubes / Valves 3 9th November 2010 07:13 PM
Simplest 6080 or 6AS7 OTL Project? Michael Rothacher Tubes / Valves 29 26th August 2010 08:05 PM
10 - 16 ohm project for Atma-Sphere OTL amp j.burtt Multi-Way 2 8th May 2006 05:34 PM
