New Tim Mellows OTL project
Old 21st January 2012, 10:00 PM   #11
flatheadmurre is offline flatheadmurre  Sweden
Double up on the output tubes that givs you more power.
Old 21st January 2012, 11:20 PM   #12
djn is offline djn  United States
djn's Avatar
I'll be watching this build. I want to build one but have another project ahead of it.
Old 22nd January 2012, 11:53 AM   #13
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
To me, and no offence to Tim or anyone else--The design is fundimentally flawed in its feedback loop.
The FB gain changes depending on input vol-pot position, this is sure to change the character of the sound depending on the volume control position!
Ive tried this type of FB, and was never happy with this 'colouring' effect.....
Das Beste Oder Nichts
Old 22nd January 2012, 09:05 PM   #14
cnpope is offline cnpope  United States
I tried measuring the input impedance at the grid of the input tube V1a, and it seems to be about 1.5K. This is very small compared with R1, which is 34K. I think this means that the effect you are speaking of, although real, is rather small. If my estimate is correct, I think it means the feedback, which is nominally 26dB, changes by less than about 0.5dB as the volume pot is varied. Certainly, in practice, I find no discernible change in the feedback as a function of the volume pot setting.
As Tim Mellow remarks in his article, an alternative is to hook the input to the grid of V1b instead.
Chris
Old 23rd January 2012, 12:24 AM   #15
Dimitris AR is offline Dimitris AR  Greece
I don't prefer this type of NFB too , but if you put a 100Kohm resistor and connect the volume in the input of the preamp then it will have no problem . And something else , if a small amount of DC voltage occurred in the output it will lead to a change in the bias point of the input tube ..
Old 23rd January 2012, 07:11 PM   #16
smith01793 is offline smith01793  United Kingdom
Interesting comments RE the Tim Mellows design..
I chose it for two main reasons,
1) the total cost of the build will be about the same as the tubes and transformers for something like a 300b build.
2) In my experience... the more simple a design, the better results.
I am still working on perfecting the anodising.. once the top plate is anodised the build can start hopefully this should not take me too long as I have booked a week of work
Old 23rd January 2012, 07:23 PM   #17
These pics are the mock up of top plate now stripped ready for anodising
Old 24th January 2012, 11:24 PM   #18
Mark Allen is offline Mark Allen  United States
"Double up on the output tubes that givs you more power. "
It can't be as easy as JUST doubling up on the OP tubes. You would need to increase the filament transformer capacity and the split supply power transformer capacity if you want to do this. And can the driver stage deal with two more O.P. tubes? Perhaps the best choice for me is to make two monoblocks using the existing transformers specified. Now that might increase the power out to about 50 watts @ 8 ohms IF the driver stage is capable of handling the two extra tubes. WOuld anyone care to comment on this?
Thanks,
Mark
Old 24th January 2012, 11:42 PM   #19
Thanks,
Mark
Of course its not so easy to double the output power , and the anodes of the two EF86 can't drive 4 6C33C , with large input capacitances plus the Miller capacitances , in this case you want cathode follower to drive the output tubes .
Old 24th January 2012, 11:53 PM   #20
Of course you need enough power and drive e.t.c
Doubling the tubes is the basic aproach.
New Tim Mellows OTL projectHide this!Advertise here!
OTL designed by Tim Mellow with 4 6C33C? dwhitf Tubes / Valves 380 1st November 2017 08:46 PM
Preamp for Tim Mellow's 6C33C OTL flanagan Tubes / Valves 3 9th November 2010 08:13 PM
Simplest 6080 or 6AS7 OTL Project? Michael Rothacher Tubes / Valves 29 26th August 2010 09:05 PM
10 - 16 ohm project for Atma-Sphere OTL amp j.burtt Multi-Way 2 8th May 2006 06:34 PM
