New Tim Mellows OTL project
Old 10th October 2012, 03:37 PM   #151
smith01793 is offline smith01793  United Kingdom
Default 6c33 overheated due to wrong off-set
just as a footnote = a picture of one of the overheated tubes
these 6c33 tubes really are rugged once burnt in properly,
despite this tube glowing cherry red when being over run (to the extent that the getter deposits on the inside of the glass are burnt) the tube still works ok and the bias sets up the same as a one of the other tubes when I swap them around.
I really trust Tim's design 100% and 9 months on the lesson learned is that the off sett pots do not need to be easily accessible. you could get away with having the bias pots hidden too but. the benefits are that as you crank up the bias the damn thing just sounds even better
Any Progress is Progress
Old 10th October 2012, 04:12 PM   #152
flatheadmurre is offline flatheadmurre  Sweden
I have the multiturn trimmers hidden under the topplate so the drilled hole guide the screwdriver.
One DVM atached to 2 panel jacks connected to a 0.1 resistor to check dissipation and a another DVM attached to speaker posts to check offset.
Thatīs all it takes to adjust my OTL.
And agree with your experience ones they settle they are very stable and takes lots of abuse.
Old 27th December 2012, 01:22 PM   #153
rudrud is offline rudrud  Finland
Hello!
I want to put instead C8-C11 one C = 2200-250V, as discussed in the N96. What resistance should be put in place of R23-R26?
Thank you!
Merry Christmas and Happy New Year!
Rudolf
Old 11th January 2013, 07:22 PM   #154
Tims design uses seperate resistors to to keep the voltages balanced across the capacitors, if using just two capacitors 100k across each will be okto discharge them on switch off.
Happy new year,
Tony.
Old 12th January 2013, 12:24 AM   #155
wlowes is offline wlowes  Canada
wlowes's Avatar
Default re power supply
Originally Posted by wlowes View Post
I am building a pair of otl monoblocks based on another design. I have read this thread from the beginning and hope someone can advise me based on the experience gathered here. My power tubes need +170-0-170. Circuit calls for a very standard dual power supply using a 230vct with ct to ground, and a bridge rectifier to CRC filters. ...
FYI, built the power supply and it works perfectly. Per discussion here, no CT to ground and all is well.
Old 3rd February 2013, 10:06 PM   #156
kambule is offline kambule  Hong Kong
Voltages marked on Fig 1 of feb2010 audioxpress is strange. While the HT is +-350150 and -150,
the voltage at the junction of v2 and v3 is marked -350v ??
at grid of v5 -200 ??
at grid of v4 -50 ??
Would someone share the measured values please.
Old 3rd February 2013, 11:31 PM   #157
cnpope is offline cnpope  United States
The voltages are about right. The voltage at the cathodes of V2 and V3 should be just a few volts positive of their g1 grids. The voltage on the g1 grids is set by the voltage divider composed of R8 and R10 (and also R9 and R11), with the R8 far-end at +100V and the R10 far-end at -430V. With R8= 4.7M and R10= 1.0M, that would means g1 is at about -337V. So maybe that -350V indicated in the schematic is a bit off, but only by 15V or so.
As for the grids of V4 and V5, the biasing for 200mA or so of anode current in the 6C33C requires that the grid should be at about -50V relative to the cathode. Hence -50V for V4, since its cathode is at 0V, and -200V for V5, since its cathode is at -150V.
I measured on mine, and those figures are in the same ballpark as indicated in the schematic.
Chris
Old 4th February 2013, 03:11 AM   #158
thank you
Old 30th August 2014, 09:58 AM   #159
Tyimo is offline Tyimo  Hungary
Hi!
I would like to ask some questions about the PSU:
For only one channel (in a dual mono amplifier)
- how big transformers need I? For the power tubes 250VA? For 6C33C heater 100VA and for the driving tubes 15VA enough?
- should the R33 1K be 5W?
- should the FS1 and FS2 fuses be 1.5A?
- instead of the amp meters 0.1Ohm power resistor"s wattage?
Greets:
Tyimo
Old 30th August 2014, 11:31 AM   #160
Hi!
The power unit one on both canals, therefore all values as in table 1.
("A 25W OTL Tube Amplifier" february 2010, page 17)
New Tim Mellows OTL projectHide this!Advertise here!
OTL designed by Tim Mellow with 4 6C33C? dwhitf Tubes / Valves 380 1st November 2017 08:46 PM
Preamp for Tim Mellow's 6C33C OTL flanagan Tubes / Valves 3 9th November 2010 08:13 PM
Simplest 6080 or 6AS7 OTL Project? Michael Rothacher Tubes / Valves 29 26th August 2010 09:05 PM
10 - 16 ohm project for Atma-Sphere OTL amp j.burtt Multi-Way 2 8th May 2006 06:34 PM
Copyright ©1999-2017 diyAudio
