diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   Melted my mains transformer - Where to find replacement ? (http://www.diyaudio.com/forums/power-supplies/204954-melted-mains-transformer-replacement.html)
istari knight 20th January 2012 09:54 PM
1 Attachment(s)
Hi, hopefully somebody can help me....
I have some small 8w 6P1P monoblocks & being a complete fool I inserted some EL84's which resulted in smelly smoke & blown fuses :eek:
Each of the mains transformers is now :RIP: but everything else appears okay.
I have attached a picture showing the secondary windings but I cant find suitable replacements anywhere online... Hopefully someone will know!
Any help would be fantastic, thankyou.
nigelwright7557 20th January 2012 10:03 PM
Look up specialist transformer companies but they might be expensive.
Or use more than one transformer to get the required voltages.
simon7000 20th January 2012 10:08 PM
If the transformer meets code there should be a thermal fuse in the windings. It is often just under the wrapper on a primary lead. These can be replaced! They are not very expensive!
istari knight 20th January 2012 10:27 PM
Originally Posted by simon7000 (http://www.diyaudio.com/forums/power-supplies/204954-melted-mains-transformer-replacement-post2871437.html#post2871437)
Surely if the transformers thermal fuse is blown the 1a fuse in the mains inlet wouldnt continue to blow ? I dont know, just asking.
Oh and thanks Nigel, I have emailed the manufacturer to see if they can supply them but HongKong customer service can be "iffy" so fingers crossed on that one!
simon7000 20th January 2012 10:37 PM
If the mains fuse continues to blow than the transformer is bad. Sorry to hear that! If you can't get the original part you should be able to use two stock transformers to replace the one unit.
istari knight 20th January 2012 10:45 PM
Originally Posted by simon7000 (http://www.diyaudio.com/forums/power-supplies/204954-melted-mains-transformer-replacement-post2871486.html#post2871486)
Gutted as I only got them today :(
Nevermind, thanks for your help.
bequerel 21st January 2012 07:19 AM
Check out Affordable Valve Company in Kent. They might be able to help.
Affordable Valve Company - How to contact us
woodturner-fran 21st January 2012 08:08 AM
Looks to me like that transformer is for the heaters only. 6.3 for one set of heaters, then I'd bet that 7.6v centre tapped at 250v input gives about 6.6v at 230v, and under load you end up with the 6.3v. There must be another transformer in there for the b+??
SL windings are very good to deal with and not too dear, but it's probably cheaper to buy something pulled from an old amp from ebay....
KatieandDad 21st January 2012 08:36 AM
Originally Posted by woodturner-fran (http://www.diyaudio.com/forums/power-supplies/204954-melted-mains-transformer-replacement-post2871878.html#post2871878)
Look again.
There are four windings. One Primary and THREE secondaries.
KatieandDad 21st January 2012 09:31 AM
How much room do you have to fit a replacement ?
This is a custom transformer - you have a few choices:-
1. Obtain genuine replacement.
2. Have custom replacement built.
3. Use multiple transformers.
I've found these guys really helpful but they're not cheap http://www.canterburywindings.co.uk/
If the original isn't welded together they might be able to rewind it for you - or DIY. Not impossible but VERY time consuming.
Resources saved on this page: MySQL 18.75%
