diyAudio Sponsor
Old 19th September 2003, 03:38 PM   #1
G is offline G  United States
G's Avatar
Default Quality of Hammond 300 series power transformers compared to 200 series?
Hi All,
I've ordered a 300 series power transformer from Hammond for a ongoing project and I was wondering. Do the 300 series have the same mechanical hum problem that the 200 series have? Thanks.
G
Gavin
Old 19th September 2003, 03:54 PM   #2
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
mechanical hum problem?
you sure you had it attached to your chassis properly?
Old 19th September 2003, 04:03 PM   #3
G's Avatar
I don't have it yet. I've heard about people having problems with mechanical hum from the 200 series. I was wondering if anyone had heard of or experienced a problem with the 300 series?
G
Gavin
Old 19th September 2003, 11:21 PM   #4
Fuling is offline Fuling  Sweden
My 6B4G SE amp has a Hammond 372-something in the PSU, and it does hum.
Old 20th September 2003, 01:11 AM   #5
Elkaid is offline Elkaid  Canada
Elkaid's Avatar
Send a message via MSN to Elkaid
I'm experiencing quite the same with the 182 toroidal series... But only when one of my halogen lamp is turned on at about 50%. If it's fully on, the transformer won't hum a bit.
Maybe adding some kind of line filter would help but I haven't tried it yet.
I hope this helps !
Old 20th September 2003, 08:14 AM   #6
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default Oh no, not the dreaded diode!
There's a long list of, "transformers don't like," and DC is top of the list. A lamp dimmer undoubtedly involves a switching triac, which shouldn't impose DC on the mains, but will certainly impose some nasty current pulses, and as these dimmers are always made for extreme cheapness, I wouldn't like to guarantee it can't impose DC. I've just had a horrible thought. That halogen lamp doesn't have a switch to set 50% does it? Because if it does, it achieves 50% by half-wave rectifying the mains, which is absolutely the worst imposition of DC!
Another point is that in terms of DC sensitivity, toroids are most sensitive, followed by C and R core, and lastly, EI.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 20th September 2003, 02:26 PM   #7
Elkaid's Avatar
You're right, no dimmer. Only a 3 positions switch. 100%, 50% and OFF.
It took me some time to find out that my toroidal transformer didn't like my lamp.
Do you think that somekind of line filter would do the job ?
Thanks for your comments !
Old 20th September 2003, 02:50 PM   #8
EC8010's Avatar
Default A two-tone response
Originally posted by Elkaid
Do you think that some kind of line filter would do the job?
I'm afraid not.
On parallel lines, I've recently been thinking about dimmers and decided that they are downright unpleasant things. Not only do they squirt RF everywhere, but they drastically reduce efficiency, so they waste energy. If you want to control the amount of light, it's far better to control the number of lights switched on. When I was little, prior to our house being rewired, one room had a central light fitting with three bulbs. Two bulbs were wired in parallel, and two circuits came back to the twin mains switch, giving three levels of brightness, all at the same colour temperature, and all at optimum efficiency. The next time the floors are up, those dimmers are going, and the superior 1930s technology of a trio of bulbs is going in...
Power control using a diode is an abomination and should be outlawed.
Old 21st September 2003, 03:27 PM   #9
mcs is offline mcs  Denmark
I have used two Hammond 300 series transformers and none of them hum. I use them with tube rectifiers and choke input filters though - they may hum with cap input supplies.
I have no experience with the 200 series for obvious reasons.
Best regards,
Mikkel C. Simonsen
Question about current ratings of Hammond 300 series power transformers. G Tubes / Valves 14 4th April 2009 06:38 AM
Quality of Hammond 1600 series transformers and a question about loading. G Tubes / Valves 2 24th March 2008 01:31 PM
Hammond 270 series power transformer? Norris Wilson Tubes / Valves 13 22nd February 2007 02:54 PM
power transformers in series Jaap Tubes / Valves 10 19th February 2006 08:03 PM
Difference between Hammond 200 and 300 series dsavitsk Tubes / Valves 2 24th October 2005 02:21 PM
Page generated in 0.10835 seconds (77.96% PHP - 22.04% MySQL) with 10 queries
