New Schematic Linestage Tube Preamp using EF86 & 12AX7
Old 18th January 2012, 09:01 PM   #11
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
It's been awhile since I've seen a more ridiculous design. Cascading a small signal pentode into a 12AX7 (high gain triode) is going to give one helluvalot of open loop gain. That would be OK if you needed that for NFB, but this isn't an NFB design.
Secondly, this has a -20bdv attenuator up front. Why include all that open loop gain, only to throw it away? That makes no sense at all.
Finally, driving the output directly from the 12AX7 plates is just asking for trouble. Long runs of cable, an amp with a smallish Zi, are going to load the 12AX7 right into distortion and nonlinearity. Triodes like light plate loading, and the output isn't buffered.
Take a pass on this one.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 18th January 2012, 10:36 PM   #12
Dimitris AR is offline Dimitris AR  Greece
I agree with the most said before from the other guys , and something more you include all that gain without any negative feedback , and you attenuated it in the input , but you still have high level of noise due to large amplification ( EF86 plus 12AX7 ) and due to partition noise of the EF86 in pentode mode amplifier .
Old 19th January 2012, 04:27 AM   #13
Edwind is offline Edwind  Indonesia
I'll try it from simplest one by mod this design by using NFB.
Is a buffered output necessary if input impedance of the power amp around 20Kohms with interconnect cable about 1meter (3-4 feet)?
Old 19th January 2012, 04:49 AM   #14
20K, alone, is a near vertical loadline for a 12AX7, and is way to small. Add in cable capacitance, and it'll roll over and die. Find a better design.
www.dolphin-hsl.com
Old 19th January 2012, 10:16 AM   #15
DF96 is offline DF96  England
For a short cable the low input impedance of the power amp will rescue the frequency response, but this is not the way to do audio!
Instead of fumbling around trying to patch up this design, why not try to understand all the things which are wrong with it and then start again, with your new knowledge?
Old 19th January 2012, 11:22 AM   #16
By the way, does anyone know Jadis JP200 preamp?
If know, what do you think about that?
Old 19th January 2012, 12:48 PM   #17
I just Googled the JP200. Three 12AX7 per channel (parallel triode pairs), with heavy NFB to get a voltage gain of 11. Looks like it was designed by someone more used to using BJTs, or designed a phono preamp then changed his mind.
Old 19th January 2012, 01:37 PM   #18
revintage is offline revintage
Hey Edwind,
Have you been looking at the Chinese boards at eBay for this ancient, nogood preamp. In that case, look no more....
Actually, feedback seems to be in the ballpark of 50dB!! Normally a tube preamp need 0dB.
Old 20th January 2012, 03:37 AM   #19
So what a great linestage preamps?
Maybe I can learn from it's design by build it.
Old 20th January 2012, 05:39 AM   #20
You got a good solution from me. Try it and it will take you far. And yes, you will learn too.
Think it will take 2 hours max to rebuild. Please report Monday.
New Schematic Linestage Tube Preamp using EF86 & 12AX7Hide this!Advertise here!
Cascode Tube Mic Preamp: 12AX7/12AU7 Schematic 88man Tubes / Valves 13 4th August 2012 12:08 AM
converting EF86 to take 12AX7 vintage_dog Tubes / Valves 25 5th May 2011 04:36 PM
EF86 tube preamp gaborbela Tubes / Valves 2 10th February 2010 07:00 PM
12AX7/12BH7 Hammond Tube Preamp Project jordankersten Tubes / Valves 4 5th April 2009 02:49 AM
suitable preamp for a tube amp (kt88+12ax7) kevinkuang Tubes / Valves 6 17th March 2005 02:22 PM
Copyright ©1999-2017 diyAudio
