diyAudio Sponsor
Old 16th January 2012, 09:37 PM   #1
Default Interstage coupling feedback
Hi folks,
in an interstage coupled two stage tube amp, which kind of negative feedback can be applied? I read that a feedback loop from anode of the second tube to the cathode of the first tube has to be avoided as it is a loop wraped around a transformer coupled stage. So which feedback is to be prefered as the above mentioned often sounds good with cap coupling and is practical.
Thanks, Uwe
Old 16th January 2012, 10:11 PM   #2
When the interstage transformer is a good one, with good low and high frequency bandwidth (which is not that difficult to achieve with a 1:1 type), I see no problems applying a feedback loop as phase shifts will be minimal.
You can sooner expect problems with a feedback loop from amplifier output (after the output transformer) back into the amplifier circuit as phase shifts will be larger.
Old 17th January 2012, 07:36 PM   #3
Thanks, Pieter.
TSE interstage coupling cap jrenkin Tubelab 4 31st December 2011 01:04 AM
interstage coupling Raj1 Tubes / Valves 18 19th December 2003 05:28 PM
Interstage coupling transformers Circlotron Everything Else 2 15th June 2002 11:36 PM
Page generated in 4.34691 seconds (1.56% PHP - 98.44% MySQL) with 10 queries
