Just received a Yaqin MC-10T and have a couple of questions.
Old 16th January 2012, 08:42 PM   #1
kemicalx is offline kemicalx  Australia
Default Just received a Yaqin MC-10T and have a couple of questions.
I just got my Yaqin MC-10T in the mail yesterday and I've got a few questions. I've got limited experience with valve amps. After installing the valves and adjusting the bias to 0.35v I have noticed that 2 of the 4 12AT7s are dimmer than the other 2. Across the front of the amp from the right they go bright, dim, bright, dim. The amp sounds fine, actually I'm very impressed with the sound. But comparing it to my only other valve amp, a schiit valhalla headphone amp, all of the tubes are equally bright. Should I be concerned? The only other thing I'm curious about at the moment is swapping out the factory tubes for something else. This site has some good info - 6th Street Bridge: Upgrading the Yaqin MC-10T tube amplifier
But I'm wondering if anyone here has some suggestions for affordable tubes that will give a marked improvement over the factory one.
Thanks for your time,
Ashlin.
Old 17th January 2012, 08:14 AM   #2
Actually I posted this at work, I got the order wrong, V1 is dim, V2 bright, V3 dim, V4 bright
Old 17th January 2012, 10:15 AM   #3
costis_n is offline costis_n  Greece
I think it is just construction differences, please swap them around to check. If you have the increased brightness in the same position, then it is a problem.
Old 17th January 2012, 11:04 AM   #4
I'll have a play now. This is what they look like at the moment.
Photo Album - Imgur
Old 17th January 2012, 11:16 AM   #5
Thanks mate, after swapping them around it does just look to be variations in the tubes themselves.. I also noticed one of them briefly glows brightly on start-up then dims down
Old 17th January 2012, 11:20 AM   #6
That's also normal. By the way, if you ever plan going inside this thing, please consider removing these garish blue LED's!
Old 17th January 2012, 11:24 AM   #7
hahah yer aesthetically that glowing blue logo is the only thing I don't like!
Just received a Yaqin MC-10T and have a couple of questions.Hide this!Advertise here!
Yaqin MC-10l sacpul Tubes / Valves 72 30th October 2012 02:45 AM
Questions: YAQIN MC-100B KT88 together with Spawn Sachiko? humlan57 Tubes / Valves 0 6th January 2010 02:11 PM
yaqin mc-100b jaks Tubes / Valves 7 23rd February 2009 07:11 PM
Yaqin MC-10L cruzrman Tubes / Valves 0 23rd July 2008 02:37 AM
a couple of questions re: woofer roll of (upper ) and mc-2 info Nanook Multi-Way 13 17th March 2004 06:41 AM
