#31 |
One thing you could do is wire them across your speaker terminals without your speakers attached, let your amp warm up and measure the voltage across the terminals and see if it is still motor boating.
The resistors have far less inductance then actual loudspeakers (pretty much just resistive depending on the resistor-some are entirely non-inductive, which is what you want.) The other thing you can try is to wire them in series with your speakers (effectively doubling the load the amp sees) and see if the motorboating reduces/stops by observing the cone motion. If the motor boating persists with just the resistors attached, the amp has a low freq stability problem. |
#32 |
#33 |
Since it's alternating between channels, a good place to check would be the power supply caps (clue: decoupling) especially if they are common to both channels.
| Need help troubleshooting an amplifier... | SimonB | Solid State | 3 | 14th December 2009 01:06 AM |
| Amplifier Troubleshooting. | 5th element | Solid State | 181 | 15th April 2009 04:20 PM |
| Help me troubleshooting amplifier module | fosforo | Solid State | 15 | 7th November 2006 10:59 AM |
| help troubleshooting amplifier/receiver please | JMB | Solid State | 6 | 25th October 2004 04:14 PM |
| amplifier troubleshooting | sriegel | Solid State | 0 | 6th April 2002 05:28 PM |
