Looking for unbalanced to balanced transformer
Old 16th January 2012, 05:55 AM   #11
mikvous is offline mikvous  Greece
Would one of the suggested transformers be good for converting the single ended output of a preamplifier to balanced?
Old 16th January 2012, 11:52 AM   #12
zigzagflux is offline zigzagflux  United States
zigzagflux's Avatar
Probably- you would want to go parafeed. K&K Audio would be a good place to discuss using either of those transformers as such.
Old 16th January 2012, 04:30 PM   #13
Speedskater is offline Speedskater  United States
Speedskater's Avatar
It would be good to read some of the Bill Whitlok transformer papers:
JENSEN TRANSFORMERS, INC. - APPLICATION PAPERS AND SCHEMATICS
Especially the audio transformer design chapter:
http://www.jensen-transformers.com/a...%20Chapter.pdf
Kevin
Old 16th January 2012, 05:01 PM   #14
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Thank you very much Kevin
Old 16th January 2012, 05:36 PM   #15
Shoog is offline Shoog
Shoog's Avatar
Just came across this OEP transformer;
Technical Reference
I have used one of there other input transformers as a phase splitter on a power amp. Worked out reasonably well for a cheap component.
Shoog
Old 12th January 2014, 07:07 PM   #16
The transformer is fro my friend that wants to convert the unbalanced output of the tube preamp CAT SL1-Signature +26dB of gain to balanced amp Pass X clone ALEPH-X - Pass Labs Clone Class-A amplifier PCB & schematic I have the idea to put the unbalanced to balanced transformer inside the Pass X clone. Still can be good the same advice?
TIA
Felipe
Old 14th January 2014, 07:12 PM   #17
Please help.
Looking for unbalanced to balanced transformerHide this!Advertise here!
Looking for unbalanced to balanced transformer merlin el mago Parts 9 21st January 2012 02:48 AM
Looking for unbalanced to balanced transformer merlin el mago Analog Line Level 6 20th January 2012 01:40 PM
Unbalanced to balanced transformer before UCD? sharpi31 Class D 12 5th April 2011 07:07 PM
using a transformer for balanced to unbalanced conversion h_a Analog Line Level 47 9th January 2007 10:16 AM
Balanced to Unbalanced w/ Transformer? lgreen Solid State 9 6th January 2004 04:37 AM
