I'm considering a transformer for a project requiring 400mA of current(Edcor)
but the closest one they have in stock is 325mA. How much of an effect in power output will this have? I will enquire for a custom wind,but not sure of the cost difference. Thanks
You need to give more information..
What is is powering...(OK its a project)..what part of the project B+ heaters power amp pre-amp...Voltage required...type of rectifier..etc..
The reason is..
If you under spec you will get sag..then it will run hot and the sound will be "bad" because it will clip early...great for a guitar amp (overdrive)..
It could blow open with inrush at start up with cold heater elements or capacitor inrush..
M. Gregg
More information on the planned PS design is needed, if you plan for capacitor input, you'll need significantly more current capability due to the sharp current spikes charging the first cap. With choke input, the AC current capability does not need to be higher than the DC current you want to get from it, and so on...
So please, more details!
Greetings,
Andreas
EDIT: I always tried to avoid custom wind, but ordered my first custom-wound transformer last year and was very pleased with it. You get exactly what you need, and (at least here in Europe) for a price that is acceptable.
Greetings,
Andreas
Some people use a Antek toroïdal power transformer and hide it in a car wax can for the look ... Those transformers are very cheap and also have one or two 6,3V secondary for the heaters. Look at their PDF specs for the real output voltage with your project current needs. Shipping is only 11$ in USA for unlimited weight ...I'm considering a transformer for a project requiring 400mA of current(Edcor)
Don't forget with a two diodes fullwave rectifier with capacitor input, IDC = IAC but with a bridge, IDC = 0,62 x IAC ... Also, the deep bass often need much more current than the medium frequency and it is better to choice an oversize transformer.
Alain.
- Tubes / Valves
- Power Transformer Question
