6E2 vacuum tube compatibility
Old 5th February 2012, 10:26 AM   #11
Penegal is offline Penegal  France
Hello? Blaireau, did you forget me?
Old 5th February 2012, 12:55 PM   #12
Blaireau is offline Blaireau  France
Blaireau's Avatar
Not at all, but I thought that this topic was dead, or buried. Could you precisely explain what you plan to build. It's gonna be much easier to reply with a convenient answer. But as you're not far from me, you can also use the "contact" button at the end of the 1st page from my website, and drop me a mail with your phone number. It will probably be easier to exchange ideas.
http://constructions.f6fkn.com
Old 5th February 2012, 01:12 PM   #13
"Build" is very far from what I want to do; indeed, I would like to buy a FATMAN VALVE DOCK Carbon vacuum tube amplifier which, apart from the 2 main amplifying vacuum tube, come with a 6E2 magic eye. Nevertheless, I would like to use, without any modification (considering my near zero electronics level, I find it more safe), use another magic eye with a different, and in my opinion much more pretty, pattern similar to the EM85 vacuum tube. I know that several tubes that I quoted before are at least pin compatible, but I wondered if changing the supplied tube would pose a problem and if it would work as it is.
PS: nothing personnal, but I prefer to use this forum to communicate, be it only out of concern for allowing other users to see our talk and learn from it.
Old 5th February 2012, 01:55 PM   #14
Blaireau's Avatar
So, now, I understand where the error comes from! The magic eye represented on the photo from the commercial amplifier has the pattern of a 6E3P, (NOT A 6E2P), which is totally compatible with EM84 and EM87. (double green stripe, with variable length) By the way, this type of indicator is really easy to buy from Russian stores on EB, from 5 to 10 Euros each. Some of my amplifiers are fitted with these tubes for years. 6E2P seem to have a pattern similar to EM80, 81, and 85, with a roughly triangular shape, and a variable apex. I hope that my explanations are not too difficult to understand...
Old 5th February 2012, 03:53 PM   #15
I'm trying to cling. ;-) So "my" vacuum tube is identical to 6E3P, and this tube can, from an electronical point view, be replaced with a 6E2P vacuum tube which has the pattern I want. Do I have to expect sensitivity problem (ie. different sensitivity which leads to a saturated or mostly unused display)?
Old 5th February 2012, 04:01 PM   #16
Blaireau's Avatar
I'm afraid we will never understand one each other, that's why I asked you to send me a mail. As I never replaced a 6E3P with a 6E2P, I CAN'T say it works. And as I don't own a 6E2P to do the trial, I simply can't answer your question. Sorry!
6E2 vacuum tube compatibilityHide this!Advertise here!
Vacuum Tube Voltmeters Captn Dave Equipment & Tools 15 7th February 2016 12:08 AM
Vacuum tubes, vacuum capacitors and vacuum relays GREENSTONE USA Vendor's Bazaar 0 19th August 2011 03:38 PM
Adjusting the sensitivity on a 6e2 magic eye tube bbbing Tubes / Valves 4 21st May 2010 07:28 PM
The Vacuum Tube Truth Serratoga Tubes / Valves 31 29th November 2007 09:25 PM
Vacuum Tube Pre O.C.L. gianmaria Tubes / Valves 13 16th February 2006 06:32 PM
