| diyAudio Sponsor | ||
Hello forum,
planning for a phone preamp and having not seen such a circuit so I have to ask one question: Is it possible to connect the negative RIAA feedback in a two stage phono amp from the anode of the second tube to the cathode of the first tube when the second tube is coupled with transformer coupling interstage to the line stage? This has been done many times with feedback from a transformer output stage to the previous stage without RIAA correction but my worries are the correctness of the RIAA amplitude if the anode transformer choke is a nonlinear device instead of a linear resistor in the anode? Thanks for answers, Uwe |
#2 |
Stability may be a problem. RIAA response is supposed to continue on down past 20kHz, but this may cause problems if the transformer HF resonance is too low. If you are happy debugging loop stability then fine.
| Audio Transformer/Cathode Feedback Info | LinuksGuru | Tubes / Valves | 4 | 26th April 2009 09:13 PM |
| feedback loop | rmenger | Instruments and Amps | 4 | 21st October 2006 07:04 PM |
| feedback loop | rmenger | Parts | 0 | 29th July 2004 01:24 PM |
| Resistor value in the feedback loop | FredG | Chip Amps | 12 | 6th February 2004 08:08 PM |
| Feedback Loop help | KevinLee | Solid State | 4 | 1st December 2002 01:39 AM |
| Page generated in 0.07238 seconds (70.68% PHP - 29.32% MySQL) with 10 queries |
