| diyAudio Sponsor | ||
yaqin vk amp without the loudness button uk version. i have had my amp for 6 months now using marantz cd player cd6003 and monitor audio rs6. my amp sounds to clear with no bass. it sounds like when the singer is singing they are shouting sometimes. i have replace speaker cables new audio connections with no luck still. does anyone no why i am having these problems. doing my head in now. what replacement valves would be the best choise for me cheers lee
#2 |
Doubt valve change will do anything at all--Unless one is faulty!
Speaker wires in phase??
Das Beste Oder Nichts |
#3 |
What is the model?
Is it the eBay "YAQIN VK-2100 Integrated Valve Tube Power Amplifier Amp" selling for 300 pounds? If it is, check Yaqin VK-2100 mods You will find a lot of information and modifications taht you can do to tailor the sound to your taste... also some people reports that "Some might find this amplifier a little bright and forward"...
If You need something done properly, do it yourself (and ask help from DIYaudio... One of my SE 211 tube amps: http://sites.google.com/site/sunajeb...ificador-211se Last edited by Jebem; 14th January 2012 at 05:23 PM. |
#4 |
yes mate i brought it from ebay. but my amp does not have a loudness button on it like most of them do. cheers for your reply mate
#5 |
Welcome! We like puzzles, so we try to help each other.
As stated before by Alastair, the obvious reason to lack bass is to have the speakers working in opposite phase, so make sure they are correctly wired. You have nothing to lose, why not reverse the wiring on one of the speakers and see the result. And what about the monitor audio rs6? If they are new units they need to run (burn in) a few days more before getting a more "warm" sound. Some people reports that they have "extended highs", so the amp must have a clean output without putting to much emphasis on high frequencies or else the speakers will show it. Most of the times is a matter of finding a good combination of amp + speakers + source to make the "sound" we like. Can you try a different pair of speakers? Maybe you can take your amp to a showroom and tested it with different speakers.
If You need something done properly, do it yourself (and ask help from DIYaudio... One of my SE 211 tube amps: http://sites.google.com/site/sunajeb...ificador-211se |
#6 |
#7 |
thanks mate. i have tryed them on my brothers b&w sounds just the same using with naim cd player ot look there cheers lee. mybe i will try a graphic equilzer and see if that will sort it out for me cheers lee
#8 |
A EQ will be a band-aid solution... at best.
Find the issue/problem and address that, rather than try and cover it up.
Speakers; Lenehan ML-1 - Amp; 25wpc El34 Custom - Phono; Boozhounds jfet - Turntable; Sansui SR838. |
#9 |
| Yaqin VK-2100 mods | Rockmore | Tubes / Valves | 61 | 23rd May 2012 11:53 PM |
| Yaqin VK-2100 hybrid running 4 ohm speakers | Rockmore | Tubes / Valves | 2 | 9th April 2012 01:55 PM |
| Yaqin VK-2100 Static from one channel | aclimbatize | Tubes / Valves | 5 | 13th August 2011 03:57 AM |
| Yaqin Valve Amplifier UK Sales & Service | marktravuk | Vendor's Bazaar | 3 | 16th November 2007 04:55 AM |
| The Loudness button | 2litre | Everything Else | 15 | 25th November 2006 11:04 AM |
| Page generated in 0.10370 seconds (79.34% PHP - 20.66% MySQL) with 10 queries |
