Single ended at 24Vcc 1+1W @ 8 ohm - three tubes - Page 5 - diyAudio
Old 22nd January 2012, 08:11 PM   #41
pilovis is offline pilovis  Italy
The prototype on the youtube clips uses two line transformer 220V/24V 40VA as output transformers
Old 22nd January 2012, 08:18 PM   #42
M Gregg is offline M Gregg  England
Thank's..might try the mozener in the cathode bias circuit...
I'll have a think and see what happens
M. Gregg
Old 22nd January 2012, 08:48 PM   #43
M. Gregg
Could you please give me more details about mozener?
Old 25th January 2012, 12:31 PM   #44
Audio test of PL504 @ 35Vcc with line trasformer 220/24V as output transformer:
http://www.youtube.com/watch?v=V1F7q...layer_embedded
Preamp = 1/2 ECC82
Old 24th July 2013, 09:46 AM   #45
hello ,
me copy your build , up to élévate HT to 150 V= or upgrad to 250 V=
you are no tested to big voltage ?
Old 24th July 2013, 09:50 AM   #46
You can increase anode voltage up to 160 Vcc without any problem, just adapt electrolitics capacitors voltage.
Old 24th July 2013, 09:56 AM   #47
You can increase anode voltage up to 240 Vcc without any problem, just adapt electrolitics capacitors voltage.
hello ,
i me tested to build , and me problem for use transformator adapted to impédance audio !
me old build , so risk no assymétric audio and build CR for good appréciate music ?
Old 24th July 2013, 10:08 AM   #48
Originally Posted by jean michel View Post
hello ,
If you increase PL504 anode voltage above 90V, you should use real audio output transformers (600-800 ohm) instead of using the line transformers as I suggested for the 24 Vcc prototype.
Audio transformers improve bandwith and also limit the risk of core saturation due to c.c.
Old 24th July 2013, 10:15 AM   #49
If you increase PL504 anode voltage above 90V, you should use real audio output transformers (800 ohm) instead of using the line transformers as I suggested for the 24 Vcc prototype.
okey , thank
Old 24th July 2013, 10:24 AM   #50
This one could be OK.
TU020
813 RCA amplifier - 25w, class A1, single ended,2 tubes,Rout~1ohm audiodesign Tubes / Valves 5 19th September 2010 07:34 PM
VR tubes in single ended circuits Jeb-D. Tubes / Valves 1 4th February 2009 12:31 AM
Single Ended Amp 8 Ohm To 4 Ohm Conversion jsaults Parts 11 21st February 2007 01:00 PM
FS: 300b single ended stereo amp w/tubes Magnetmaz Swap Meet 1 21st July 2004 04:31 AM
Copyright ©1999-2017 diyAudio
