Single ended at 24Vcc 1+1W @ 8 ohm - three tubes - Page 3 - diyAudio
Old 14th January 2012, 10:42 AM   #21
pilovis is offline pilovis  Italy
Originally Posted by jane View Post
Max theoretical class A output power depends on the quiescent current (Iq) and the reflected load of the transformer (Rl).
Iq=35mA and Rl=600 ohm should give about 0.37 watt.
To increase otput power reduce the catode resistor of PL504 as low as 22 ohm and eventually use 4 ohm speakers, distortion wil not suffer too much.
Old 20th January 2012, 01:05 PM   #22
Component side:
Old 20th January 2012, 01:08 PM   #23
This is the final version of my 24Vcc tube stereo amplifier.
To increase the output power I decreased the catode resistor of the two PL504s from 56 to 39 ohm.
I also added a capacitor of 100 uF 35V in parallel to the catode resistor of the two triodes of ECC82 (higher gain).
The two output transformers you see on the picture are normal line trasformers 220v/24v 40VA, they do not saturate because of such a low anode voltage (24v) and also because they are big enough. I also choosed two transformers with higher inductance to minimize losses at low frequencies.
Note: the primary impedance of these transformers is about 800 ohm with 8 ohm load on the secondary.
Old 20th January 2012, 01:36 PM   #24
Doz is offline Doz  United Kingdom
Doz's Avatar
That's really interesting. Especially as I have a bucket load of 24V toroidials, and two bucket loads of PL504's!!
"To err is human.. to make a real balls-up requires a computer"
Old 20th January 2012, 01:46 PM   #25
If you don't use batteries pay particular attention to the 24Vcc filtering to avoid 50/60 Hz noise.
I used a 4.700 uF 63V capacitor after the diode bridge, than i connected the secondary of an old transformer 220v/12v in series at + line as a filter inductance, and another 4.700 uF capacitor at the output.
Old 20th January 2012, 01:50 PM   #26
M Gregg is offline M Gregg  England
OK I see the air variable cap where is the radio that goes with it?
Just joking
Nice to see your progress
And development.. The case should be interesting...
M. Gregg
Old 20th January 2012, 01:52 PM   #27
I don't know if toroidals are suitable for this S.E. circuit.
Toroidals saturate easily with direct current and also have smaller inductance that cause low frequencies losses.
Anyway, you can try and let me know.
Old 20th January 2012, 02:09 PM   #28
Dead
Old 20th January 2012, 02:33 PM   #29
Doz's Avatar
Point taken , back to root in the junque box !
Old 20th January 2012, 02:49 PM   #30
Alastair E's Avatar
Nothing wrong with valves at low voltage...
I made a pre-amp a while back that used 6SN7, first half as gain stage and second as cathode-follower, Worked very good at only 12V...
Tried a variety of valves such as ECCxx and even Nuvistors there, but the best was a 6/30L2, gen. purpose double-triode.
As an improvement to the O/P's amp, maybe a ECC86 would be a better choice than ECC82, as it was designed for low-voltages....
A MOSFET voltage reference (Mozener) in the cathode of PL504 could give benefits in place of the cathode-resistor, and give adjustable bias too....
Das Beste Oder Nichts
813 RCA amplifier - 25w, class A1, single ended,2 tubes,Rout~1ohm audiodesign Tubes / Valves 5 19th September 2010 07:34 PM
VR tubes in single ended circuits Jeb-D. Tubes / Valves 1 4th February 2009 12:31 AM
Single Ended Amp 8 Ohm To 4 Ohm Conversion jsaults Parts 11 21st February 2007 01:00 PM
FS: 300b single ended stereo amp w/tubes Magnetmaz Swap Meet 1 21st July 2004 04:31 AM
Copyright 1999-2017 diyAudio
