RH84 amplifier build, but very weak distorted output
Old 12th January 2012, 10:27 PM   #1
vermeero is offline vermeero  Netherlands
vermeero's Avatar
Default RH84 amplifier build, but very weak distorted output
Hi all,
Haven't posted much yet, been here occasionally to get some inspiration!
Last week I build the RH84 amplifier (SE EL84) and since this is my first real build I closely followed the original schematics...which means I didn't change any values. I even ordered a powertransformer wound to spec. according to the schematics. Original to be found here: RH 84 - Tube Audio ...... RH DESIGN
When I power it on and wait for a while having a preamp connected with music playing at a fairly loud level, only a very weak sound is heard from the loudspeaker, mostly from the left channel. When I really cranck up the volume it doesn't get much louder but it turns out distorted.
Really searched and searched, checked my wiring and placement of components but I can't find anything wrong. Swapped the EL84's but no change.
Measured some voltages (always with the negative pin of my meter connected to the amplifier's ground) and they appear like this:
B+ : 353
Right channel EL84:
pin 3: 11,9
pin 7: 332
pin 9: 343
Left channel EL84:
pin 3: 12,3
pin 7: 330
pin 9: 342
ECC81:
pin 1: 341
pin 6: 317
Filament voltage is like it should be.
After about a minute or two I switched it off... thinking this can't be good.
No hum actually.
Old 12th January 2012, 10:39 PM   #2
DF96 is offline DF96  England
Where is DC isolation? The RH84 does not appear to have an input coupling capacitor and your ECC81 triodes don't appear to be taking any anode current.
Old 12th January 2012, 10:55 PM   #3
vermeero's Avatar
To clarify myself more... an added photo from the wiring inside the cabinet I build.
About the picture... the AC is grounded (before I started testing the amplifier), so now a wire from AC ground runs to the central ground of the amplifier itself.
I'm really new to this... trying to learn through reading etc.
So... what do you mean by isolating the DC?
p.s.
What struck me is the high voltage on the primary of the output transformer... how is it supposed to make a voltage swing when it's this high for an EL84?
Old 12th January 2012, 11:06 PM   #4
How are your heaters wired? I suspect you may be supplying 6.3V to ECC81 pins 4 and 5, but no connection to pin 9. You either need 12.6V to 4 and 5, or join 4 and 5 together and put 6.3V between there and pin 9. This would explain why the ECC81 is taking no anode currrent - the cathode is not hot enough.
Old 12th January 2012, 11:36 PM   #5
vanofmonks is offline vanofmonks  United States
I agree with DF96. The ecc81 heaters not wired correctly.
Old 13th January 2012, 12:32 PM   #6
vermeero's Avatar
Thanks a lot! I knew it had to be something simple... just didn't look closely enough at the ECC81's pinout.
The amplifier is now working as it should! No hum and goes plenty loud on a pair of Yamaha NS1000.
DF96's instruction was very clear, thanks again.
Added a picture of how it's wired now.
Old 13th January 2012, 12:34 PM   #7
GloBug is offline GloBug  Canada
Banned
Right on!
RH84 amplifier build, but very weak distorted outputHide this!Advertise here!
My RH84 Build - first amp after a 25 year break -:) prelius Tubes / Valves 4 9th June 2011 01:58 AM
RH84 SE Build and custom Edcor power transformer BHD Tubes / Valves 7 16th March 2011 06:54 PM
BoM for an RH84 mono build? Gobble Tubes / Valves 1 29th July 2010 05:27 PM
Low and distorted output after amplifier heats up wabun Solid State 6 18th May 2010 09:38 PM
Amplifier Output Distorted Rotellian Solid State 12 10th May 2006 01:49 PM
Copyright ©1999-2017 diyAudio
