diyAudio Sponsor
Old 12th January 2012, 04:38 PM   #1
Default Equalize or Not Equilize when driving a tube amp ?
I got bit by the tube bug when I bought my first MiniWatt N3. The little amp has a permanent home in the bedroom driving a pair of Energy CB-20 speakers. I get to listen to it often. Now it's time to upgrade the sound system in the living room. I've got an old Kenwood KR 350. I've had it since I was in my early twenties. Now I'm upgrading with a Jolida 202s. I plan on using the pre out so I can connect the kenwood and still use the tuner and Techics turntable without buying a preamp right away. I'll directtly connect my Ipod to the Aux input, any equalization will be done on the ipod, that's what I do now. I've got an old 10 band Realistic Graphic Equalizer that has worked well with the Kenwood Amp. Have any of you fed the Main out from the equilizer to a line in of a tube amp ? Main Out = Line out but I was wondering if I was just better off with no EQ in the loop.
Eventually I'll just have the Ipod, Turntable (connected with a tube based phono preamp) , and eventually a HD Radio will take the Kenwoods place
I'm hooked on the soundstage and detail that you can easily hear with a tube based amp. Do you loose anything when you add an equalizer ?
Old 12th January 2012, 04:43 PM   #2
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I believe that if the audio levels and impedances are comparable between them, there mustn´t be any trouble. Looking into the amplifier from the input terminals, tube or not tube amplifiers are almost equal.
LW1DSE
Last edited by Osvaldo de Banfield; 12th January 2012 at 04:49 PM. Reason: mistake
Old 12th January 2012, 04:53 PM   #3
kevinkr's Avatar
I'm a purist so I would say try it without and if the sound is really not to your liking then add the EQ.. Note also that you have probably become used to the way it sounds Eq'd so it might take some fiddling with speaker placement and time for you to like the unequalized sound.
www.kta-hifi.net
Tube amp specifically for driving ESLs bigwill Planars & Exotics 183 9th January 2009 02:08 AM
Equalize a passive bi-amp system Sony Solid State 1 1st September 2005 02:54 PM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 06:47 AM
My center spkr. How do I equalize for...? Lito Multi-Way 3 21st December 2003 02:44 AM
Need advice driving a tube Bernhard Pass Labs 8 7th July 2003 06:17 PM
Page generated in 0.07387 seconds (72.77% PHP - 27.23% MySQL) with 10 queries
