EL156 PP
EL156 PP
Old 28th May 2012, 10:42 PM   #21
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
EL156 PP
ClassAB1 B+ is 600volts with 3500 anode to anode load for an output of 200watts....AB2 gives more power at 300watts...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 28th May 2012, 10:50 PM   #22
7N7 is offline 7N7  United Kingdom
7N7's Avatar
I would love to play with that one as a triode; I'll bet it's a corker.
One ought to write a book about the final flowering of valve development in Europe and the US; personally whilst I think it's a good thing that old types are being manufactured in China, these late developments are much more exciting to me - as I say to everyone I was only ever in this for the valves themselves (though I am a music lover).
Now then I wonder if there are some nice late Soviet types still sitting in warehouses in Russia? They must have made stuff like this surely?
Paul
Plug them in and light them up
Old 28th May 2012, 11:26 PM   #23
TonyTecson's Avatar
EL156 PP
Paul
i have a quad of these tubes and i am looking for more, before i start doing something with them.....
i am sure the russians came up with something simmilar, maybe wavebourn can chime in to help us out.....
Old 28th May 2012, 11:32 PM   #24
7N7's Avatar
Perhaps he will!
I could kick myself for having sold off my YL1150s; I just looked at the data.
How about Ra of 134 ohms as a triode? Even a real-world Ra of say 200 ohms would mean a very good output transformer = for p-p 1k - 1.5k a-a would be fine and with 75W pa one might just have a very nice 40W triode output stage.
Paul
Old 29th May 2012, 12:41 AM   #25
jazbo8 is offline jazbo8
jazbo8's Avatar
EL156 PP
Originally Posted by es345 View Post
... agreed...
Hans- Georg
Looks really rugged! Got schematic for it?
Jaz
Old 29th May 2012, 01:38 AM   #26
TonyTecson's Avatar
EL156 PP
Perhaps he will!
Paul
Ra is of 134 ohm is 6C33 like.....very easy to design and build opt's, i recently started a 6c33 set amp build, the opt was 600:6 ohms.....
Old 29th May 2012, 04:00 AM   #27
Positron is offline Positron  United States
And what happens when the price increases, or quantities are low? By the way, check out the G2 ratings. I would suggest sticking with something dependable and good, and who needs hundreds of watts.
Are you sure the tubes arcing was not a result of oscillations or no load (from open speaker coil/winding/connection), which would substantially raise the plate voltage?
Cheers.
Old 29th May 2012, 05:12 AM   #28
TonyTecson's Avatar
EL156 PP
prices are steep, U$125 on an ebay store....this tube can be a good candidate for screen grid drive imho....
Old 29th May 2012, 05:19 AM   #29
FLT is offline FLT
Jaz
Look here:
Bass Power Amp with GU50
regards
Old 29th May 2012, 08:17 AM   #30
7N7's Avatar
Cheers.
Well a good example of this is 6146B. A nice little power valve with a screen grid limit of only 250V. Philips published a circuit diagram for a AB1 amplifier running the valves at 400V. ANd 807 is safe at 400V too,
13E1 is another: limited to 300V on g2 and with very high gm (35). I built an amplifier with these over ten years ago. Whilst developing, I tested a secondhand 13E1 as a triode at 500V and 200mA; it was fine.
However I DID have trouble with E55L as a triode; this one developed internal shorts in two new examples, bur I was running these as triodes only 25V over the maximum g2 limit!
EL156 PPHide this!Advertise here!
Medium Power SET, EL156 based Joshua_G Tubes / Valves 33 15th November 2011 01:21 PM
300B/EL156 Amp avico78 Tubes / Valves 4 29th July 2010 10:01 PM
EL152, GU50 and EL156 eeyore Tubes / Valves 22 29th April 2010 07:58 AM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 12:36 AM
