diyAudio Sponsor
Old 11th January 2012, 09:07 PM   #1
Default 300B resistor
Anyone know where I can find the resistance of 880 ohm-25W to
the 300b. I have a put a wound adjustable, but I think they are
the metal best inductivas.Les not sent photos.
Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
http://tinypic.com/r/258t06r/5
Old 11th January 2012, 09:30 PM   #2
Sandor is offline Sandor  Italy
I think that for a single 300B these 12W non-inductive resistors are sufficient:
Mills resistors page
I use them in my 300B SE amp and the work wery well.
Paul
Old 11th January 2012, 10:39 PM   #3
With Mills resistors You need cathode cap about 1000 uF with very good quality, like Black Gate with U = more 100V, that has expensive price.
If You have possibility connect 300B with fixed bias, this is better idea with better sounding.
Old 11th January 2012, 11:47 PM   #4
tomchr is online now tomchr  United States
tomchr's Avatar
If you want the bias to be adjustable, you won't need the entire 880 ohm range. I suggest using a 200 ohm wire-wound pot in series with a larger power resistor (750 ohm should be about right). You can make a large power resistor by putting many resistors in parallel. For example two 10 W 1500 ohm resistors in parallel would make 750 ohm, 20 W.
The power dissipated in the potentiometer can be calculated from P = I^2 * R. As the 300B is limited to 100 mA, the worst case dissipation with a 200 ohm pot is 0.1^2 * 200 = 2 W. If the pot is closer to the center of its range, you'll get 1 W. A 5 W wire-wound pot is probably OK here...
~Tom
"50 % of the game is mental and the other 50 % is being mental. I've got that part down, no problem."
http://www.neurochrome.com/audio
Old 12th January 2012, 02:17 AM   #5
DHT112A is online now DHT112A  United States
Here:
Angela Instruments Online Catalog - Resistors - Wirewound
or here:
Huntington TMC 880 ohm - Handmade Electronics
Both in US
Old 12th January 2012, 01:50 PM   #6
Troncones's Avatar
If the 300B (or any tube) is operated in Class A and has a bypass cap does the cathode resistor actualy see AC? Does it need to be non-inductive?
The Myth: A hand full of Tubes, Caps, Resistors and Iron and you have an Amp. The Reality: You have self induced Dementia. Newbie.
Old 13th January 2012, 02:35 AM   #7
tomchr's Avatar
That's a good point, actually... The time constant of the cathode cap and resistor is typically set to form an LF pole in the 2~10 Hz range. So the resistor shouldn't really see much AC in the audio range.
That said, I generally find that many people obsess over the inductance of resistors. I've measured some general purpose 0.25 W leaded axial thin film resistors on an impedance analyzer. The impedance curve was completely flat (resistive) out to 40 MHz.
I'm also amused by the people who recommend placing non-inductive resistors right at the tube pin only to have the other end of the resistor connected through 50 mm of wire. Mind you that the self inductance of a piece of wire is around 1 nH/mm (rule of thumb).
~Tom
Old 13th January 2012, 02:34 PM   #8
Troncones's Avatar
Thnaks Tom,
I quess I should have included "in the audio range" in my question.
At times there does seem to be a lot of obsession on the minute. Seperating the wheat from the shaft is one of the challanges for a Newbie.
Tom
input resistor on the JE LAB 300B ixe13 Tubes / Valves 14 21st December 2010 05:06 PM
bias resistor to use for a PP 300B? jonusgrumby Tubes / Valves 1 12th January 2009 09:48 PM
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 01:13 PM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Page generated in 0.10816 seconds (78.01% PHP - 21.99% MySQL) with 10 queries
