Old 12th January 2012, 08:40 AM   #11
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
Originally Posted by simon2a3 View Post
Why's that? Never heard of that before.
As dhaen says..
EG mount the cap on its own tag board connections and link to the resistor (even a short link is still better than direct on to the resistor leads) if the cap acts as a heat sink its life will be short.. + a hot cap can have a different sound..
M. Gregg
What is the sound of one hand clapping?
Old 12th January 2012, 08:54 AM   #12
M Gregg's Avatar
Originally Posted by mbede View Post
Hello Gregg, what would be the difference in sound of Elna cerafine vs. Silmic II?
I think its more a case of how each interact with the rest of the circuit..and tube you are using..taste etc.. One is warmer the other is brighter..<<detail is different in how its presented..if you click them in my post they are linked to HIfi collective just for an eg of price (I have no connection) there is a link on the page (small writing) that will take you to manufactures info and a short blog..
They are so cheap you could try both and see...just remember that a 1 hour test is no good give it a week for each..
Black gate would also be a good choice the trouble is getting them and cost..
M. Gregg
Old 12th January 2012, 07:30 PM   #13
RajkoM is offline RajkoM  Bosnia and Herzegovina
Default Cathode bypass cap
Hi Marko.
I saw that you are fan of exotic components with astronomical prices. You should ask C. Van Haus to make CuTf or TfTf capacitors for you
Seriously, 47uF/160V/SET.... output tube cathode bypass, I guess.
For me, forget electrolytics. Also forget any MKPs, because it sounds too harsh (Solen), harsh (Ansar) or too "sssssssss" (Supreme).
My recommendation:
1 - Siemens MKV 125Vac (B25811 type). I use NOS 2x15uF in parallel. If I know well, today Epcos B25811MKVs products in Russia for the Russian market only.
2 - Bosch/Siemens/SEL MP type. These capacitors are huge and need more space for them.
3 - Russian MBGO 160V (only MBGO, not others).
4 - No four.
Best diying
Old 13th January 2012, 12:40 PM   #14
Originally Posted by M Gregg View Post
As dhaen says..
M. Gregg
Fair point. Everything I build is breadboarded so I never really consider the long term issues, plus everything's open so the heat escapes. One day I'll use a box though so it's well worth remembering, for output valves at least.
Old 13th January 2012, 01:58 PM   #15
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
...would you use in SET amplifier if you had voltage of approx. 100v and 47uF as requirements?
I would suggest to convert to fixed or semi-fixed bias instead and put a high quality capacitor in the final power supply position.
If for reason self bias must be kept I would use a high quality film capacitor.
However I would connect an additional capacitor with a value of appx. Ck / (Mu-1) between cathode and the +B connecton of the output transformer and I would a resistor of approximately the DCR of the output transformer between the power supply and the +B connection of the Output transformer.
Precise values are best fine-tuned in circuit, with the extra C adjusted for minimum output noise from the Powersupply (this means a very quiet DC supply must be employed) and the Resistor should be tuned for a low frequency response without Bump (output stage only, not complete amplifier).
Ciao T
Old 14th January 2012, 05:23 PM   #16
Default Bump
Ciao T.
You mentioned Bump. Talking about self bias, bump is usually a consequence of speaker crossover performance, not value of capacitor in cathode bypass. Such were my experiences.
Something similar with fixed bias ???
Question about cathode bypass capacitor: rockgardenlove Tubes / Valves 4 24th October 2008 08:34 AM
What size capacitor I use for a 2A3 or 300B cathode bypass? sgerus Tubes / Valves 20 4th March 2008 02:18 PM
Choosing A Cathode bypass capacitor alexmoose Tubes / Valves 11 7th April 2007 09:14 AM
Question about cathode bypass capacitor argo Tubes / Valves 15 20th February 2005 10:26 PM
Does a cathode bypass capacitor reduce hum? ray_moth Tubes / Valves 23 21st August 2004 01:38 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
