diyAudio Sponsor
Old 9th January 2012, 07:10 PM   #1
rongon is offline rongon  United States
Default Source follower in a DC-coupled pp amp?
I want to add MOSFET source followers between the phase splitter/driver LTP and the output tubes of my 2-stage DC-coupled 2A3 PP amp. I figured it with cathode followers, and it looked pretty easy to do. Here it is in a similar fashion, but with MOSFET's.
Did I do that right? I suspect there's more to it than that...
I figured on about 160V dropped across the current sinks below the FET's sources. About 20V drain to source. 10mA is enough?
Old 9th January 2012, 11:06 PM   #2
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
Hey ... would you mind telling more about that choke on the 6N6P?
Tks
Old 10th January 2012, 01:47 AM   #3
Well... It's actually a push-pull OPT designed for EL84's in pentode. I'm just using the primary as a center-tapped choke, as the plate load for the 6N6P. I figure it has enough inductance for that use, and measurements bear that out. The amp passes pretty decent sine waves well below 20 Hz at 6 watts RMS out.
A purpose-designed split load choke like the Tango TC-160-15W would be better, I'm sure.
But I was hoping to hear from someone about using the MOSFET's that way...
DC coupled cathode follower driving me nuts funk1980 Tubes / Valves 12 9th November 2011 05:48 PM
True direct-coupled PP amp JesseG Tubes / Valves 20 15th January 2010 04:17 PM
Direct-coupled cathode/source follower driver in PP? ray_moth Tubes / Valves 83 17th July 2008 02:53 AM
IRFBC20 as source follower drivers for EL34s in AB1 PP ray_moth Tubes / Valves 21 21st March 2008 05:43 PM
Power follower class A Mosfet DC coupled. Mr. Steve Solid State 30 15th February 2006 06:04 PM
Page generated in 0.07562 seconds (71.97% PHP - 28.03% MySQL) with 10 queries
