High voltage driver for AB2 operation GU81m tubes
Old 13th August 2012, 09:50 AM   #261
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
before potting you can test the opt.....then when everything works out good, you can start potting those OPT's.....your traffo maker should be able to do that for you...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 13th August 2012, 09:54 AM   #262
Alexontherocks is offline Alexontherocks  Italy
testing the opt or potting it?
either way it can't be done realiably. I must test the opt in action with the gu81m and it would be very expensive to have the toroidals sent back for potting.
installation in my chassis is difficult to so I will have to work with the opt "outside" the amp before final installation.
what would be a good way to dessicate the amp? airtight storage with silicagel for a few days?
Old 13th August 2012, 10:05 AM   #263
TonyTecson's Avatar
i mean potting it......
in that case you will have to pot it yourself....if you can find a suitable container and epoxy compounds, you can diy....
Old 13th August 2012, 12:12 PM   #264
epoxy I have plenty (I used to make my own carbon fiber parts for my motorcycle)
Container, will a plastic toroidal container suffice?
I have a picture of some testing on the driver.
I need a x100 probe to proceed further. The scope at 50v/div clips.
The 6bl7 can really take a beating. I made all sorts of mistake working on it and it is still kicking!
Old 13th August 2012, 12:15 PM   #265
TonyTecson's Avatar
looking good.....
so you have experience with carbon fibre, that will even make a good encapsulant for your opt'S....
Old 13th August 2012, 12:34 PM   #266
really? do you think a carbon fiber encapsulation is worth exploring? I can easily make one with a stamp of the container as template.
Old 13th August 2012, 12:39 PM   #267
TonyTecson's Avatar
you have everything.....go ahead and do it...
Old 13th August 2012, 12:40 PM   #268
ok. I will.
I can either wrap an existing container in CF or make an entire new container. What do you think?
Old 13th August 2012, 12:43 PM   #269
Tubelab_com is online now Tubelab_com  United States
Tubelab_com's Avatar
I will install 4kv GDTs in clear glass tube envelopes
I'm not so sure that is the answer. I worked with lower voltage GDT's about 20 years ago to protect line powered radio equipment mounted in remote locations where the power source was less than ideal and lightning strikes were guaranteed.
We used devices made by CP Claire and Siemens. The GDT functions much like a neon bulb or a 0B2 regulator tube. It has a speciallized gas mixture inside so that once the strike voltage is reached an arc will occur causing the voltage across the device to drop. The ones made to operate directly across the power lines can carry a huge amount of current for one half cycle, about 16mS on 60 Hz. The arc should extinguish when the line voltage crosses through zero.
We were getting field failures where the GDT had melted and in some cases the arc continued after the GDT ceased to exist destroying the PC board and most of the device. I could not duplicate this destruction in the lab.....until I duplicated the field conditions where the device could be powered by several hundred feet of wire between the device and the power company distribution transformer. The same power source was also operating several kilowatts of sodium vapor lamps.
After a consultation with the GDT vendors engineers, we learned that the GDT must experience a zero crossing of its supply voltage in order to extinguish. This must come before the critical temperature is reached where the device will auto-strike on the next half cycle. In our case the sodium vapor lamps and their solid state ballasts were poluting the power source such that there was no clear zero crossing, and the GDT never extinguished.
I believe that you may be in the same situation with a constant DC voltage across the GDT. Maybe the devices have improved in the past 20 years, I don't know. I would check with the vendor, or perform some experiments before risking a possible catastrophic event.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 13th August 2012, 12:44 PM   #270
TonyTecson's Avatar
Originally Posted by Alexontherocks View Post
ok. I will.
good plan...
High voltage driver for AB2 operation GU81m tubesHide this!Advertise here!
High Voltage BjT's for Pre-driver stages of High Power Amplifier - Overview tiefbassuebertr Solid State 73 14th September 2017 12:49 PM
Why high voltage Fets when low voltage types gives less distortion? Circlomanen Pass Labs 21 9th December 2009 09:43 PM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
A high voltage drive fully differential driver/op amp Russ White Pass Labs 21 18th July 2007 10:14 PM
gu81m ik3ssj Tubes / Valves 4 4th March 2007 03:41 PM
Copyright ©1999-2017 diyAudio
