High voltage driver for AB2 operation GU81m tubes
Old 30th May 2012, 12:23 PM   #161
Alexontherocks is offline Alexontherocks  Italy
Thanks! I really appreciate the encouragement!
Actually work is progressing much more slowly than I would like. What really helps is to think things over and over...really imagine the assembly in every aspect before even touching the screwdriver. This way when the time comes to build, every forseen problem is addressed swiftly (obviously there is a margin for error). I think the amp will work well. In any case the driver section can be redesigned and swapped for something better in a very short amount of time. I am eager to test the power section. Once that is done it will just a matter of starting the testing phase.
I think the bass response will be really exceptional. Many have described music played by large tubes as "effortless". can't wait to corroborate this idea!
Old 30th May 2012, 12:24 PM   #162
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
go slow...haste makes waste...are you affected by the earthquake?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 30th May 2012, 12:28 PM   #163
here is the video
http://youtu.be/F8Jh4s9j9rk
the filaments are sofstarted via a 4A 10ohm NTC thermistor....the main switch triggers the timer which in turn activates the softsart module. This will force the surge to flow through 4x NTC thermistors. After 1.2s the thermistors are bypassed by a relay.
Old 30th May 2012, 12:43 PM   #164
Very true. The best part is yet to come...for now it is just boring mechanical work. I still have to wait for the sockets to be sandblasted and powdercoated.
Thanks for the question. Very kind of you. Luckily no I live in the least sismic area of Italy and just felt the smallest amount of tremors. At 9 o'clock yesterday the tremor was noticeable but not cause for concern.
The amp is so heavy I was pretty confident nothing could happen.
Old 31st May 2012, 04:32 PM   #165
burning tubes...
all filament transformers in the amplifier are connected to mains via a NTC thermistor (CL-60) 10ohm @ 25C
Only the rectifier filaments do not draw enough power to lower the thermistor's resistance to an acceptable value...therefore with only the rectifiers on I get 2.1v instead of 2.5v.
I hope this will solve itself when the gu81m filament transformer will draw its own current.
for now...some burn in tests
xenon
mercury
If anyone has any suggestions for ux4 compatibile rectifiers I am all ears (no pun intended). This will be a great testing platform for future experiments
Old 31st May 2012, 04:36 PM   #166
Also a question...
I want to move inputs and outputs to the front of the amplifier
the front plate is 10mm thick. I can get away with it as far as the outputs (since the threaded connectors are very very long) but input s going to be a problem. Can anyone point out a connector, with a round footprint, which will mount on a 10mm thick panel? I thought of 6,3mm jack or RCA but both seem too short.
Old 31st May 2012, 06:19 PM   #167
voltage boards fitted
need to dremel out a pice to allow for the bank of b+ caps.
Old 3rd June 2012, 09:05 PM   #168
unfortunately I have very little time to post this picture...so let us say somethings work, other don't
Old 3rd June 2012, 09:13 PM   #169
djn is offline djn  United States
djn's Avatar
Wow, looks like the Genie is about to jump out of the bottle. Kind of a cool picture though.
Old 3rd June 2012, 10:13 PM   #170
7N7 is offline 7N7  United Kingdom
7N7's Avatar
Originally Posted by Alexontherocks View Post
Also a question...
Is the front panel removable?
If so what you need is a counterbore. A counterbore is a drill - for example that begins as say a 6mm drill further along it becomes like an end-milling cutter, so you might have say a 6mm pilot hole followed by a 22mm flat cut. With care this would enable you to reduce the thickness of your panel where needed,
Paul
Plug them in and light them up
High voltage driver for AB2 operation GU81m tubesHide this!Advertise here!
High Voltage BjT's for Pre-driver stages of High Power Amplifier - Overview tiefbassuebertr Solid State 73 14th September 2017 12:49 PM
Why high voltage Fets when low voltage types gives less distortion? Circlomanen Pass Labs 21 9th December 2009 09:43 PM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
A high voltage drive fully differential driver/op amp Russ White Pass Labs 21 18th July 2007 10:14 PM
gu81m ik3ssj Tubes / Valves 4 4th March 2007 03:41 PM
