#11 |
Any idea how much distortion the KT88s produce? I'd bet it is quite a bit.
I got about 1% out of 6SN7s at 200Vrms(540Vpk-pk) with a CCS plate load, and I don't even think that's the best tube to use for this. Not tryin' to brag, just pointing out that fly swatters will kill a fly much better than a hammer any day. |
#12 |
thanks for the suggestion!
What was your anode voltage on the 6SN7? |
#13 |
expert in tautology
what will ur plate Z target be for this amp?
working voltage? how many volts of swing will ur grid require - the output tube? it is not easy to make high power output transformers have good bandwidth... be sure to post pix of ur amp! ![]() _-_-bear
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#14 |
Keep in mind, that SRPP was exactly designed to for such an application. Driving low loads with large signal voltages. Unfortunately it only works best with a constant load which isn't case with your AB2 power tube. But since you only need a high supply voltage and two simple tubes (which only see half of the Ub) it could be worth a try.
Personally, if I had to design a driver, I would use a Anode choke and a high gm pentode.
#15 | |
400W Special Design Output Transformer About 5 years ago during a discussion of big powered tube amps a post was made with a link to Plitrons surplus page where a very similar (unpotted) OPT was being sold for a reasonable price. I bought a pair. I measured the frequency response at 100 watts to be 5 Hz to 71 KHz (+/-3db). Eight 807's in Push Pull? I have used these transformers up to 525 watts in experiments with Petes Red Board. See posts 437 and 438 in this thread: Posted new P-P power amp design Note the power output level and the drivers were common cheap pentodes. As stated by others, if you are using mosfet followers you don't need a big KT88 for the driver find a pentode that is very linear that has a high plate voltage rating. I have been doing experiments along these lines for an upcomming screen drive project and find that tubes designed for TV vertical sweep or video output seem the best choice here. As I have stated before threads about big powered tube amps come and go, but very few 200+ watt tube amps get built because of the high probablilty of failure. A little instability in a 50 watt amp might blow a screen resistor, a tube, or maybe zap a tweeter. A little instability in a 500 watt amp can reduce a very expensive collection of parts to scrap, set your house on fire, or make you dead! Work in small steps and be prepared to tweak, breadboard, and tweak again on each stage. Don't build the whole amp and plug it in!
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#16 |
thanks to tubelab and other who have partecipated....safety precautions are paramount and will be enforced at ALL times...
I am not that keen on killing myself or setting the house of fire (I do have a 3000w isolation transformer and several industrial fuse holders I can use to protect the main lines... LEXAN shielding if necessary will be installed when I will start things up. as far as the tubes are concerned... I do have spare 6Jm6 around and can easily find similar deflection tubes for tv use. Plate voltage is fairly high and seem to perform well with local feedback. (redboard docet) |
#17 |
#18 |
expert in tautology
Seems to me that if one can design and afford to build an output transformer of this power to have usable bandwidth, then making or buying an interstage transformer of equal or greater bandwidth would be easy.
Just use an interstage? Make it work at high power first, then go back and redesign the driver stage, if you still think it is needed? Also, it can't be that difficult to identify and mail order some tubes that will do the driver job. Something does not add up quite right on this project. ![]() _-_-bear
#19 |
hey-Hey!!!,
I agree Bear, it does nto add up... From a B+ of 1kV( outside edge of manageable ) and a 400 mA/tube idle point. Run g2 at 600 V. A load of between 4 and 5k a-a is called for for Class A. You'll get ~ 1k8V across the primary WITHOUT crossing into positive grid current territory( about 170V p-p g1 signal). Now this one will have a leaky grid... Consider a few volts on g3 to square up the low plate voltage side of the curves. cheers, Douglas
the Tnuctipun will return |
#20 | |
I can order any tube is required for this operation. The point being I have limited spare material (output transformers, HV cable, power transformers which can supply that voltage with THAT much current) therefore I have to have a working "backbone" which will be there if, during future experiments, I see there is need for an interstage transformer. Consider that I will need three chassis 3x 120 eur transformers: at least 600 euros worth cable (teflon/silk good for at least 20kv) and sockets 100 eur (by the way....the GU81m sockets cost 25 euros each and are 100 euros more to the list) So you see well over 1500 eur before I start soldering and I guess very few people on the forum have the kind of spare material to set a project like this in motion without buying anything If the project has a fair chance of succeeding I'd rather get a backbone working, secure HV connections and PSU, adequately feed 12.6@44A to the output tubes with little or no noise,buy and implement chokes and capacitors for 1600@several mA, test those out and then, finally get back to the driver section and tweak everything into an optimal design. Also I said nothing about timing retard and main AC softstart or safety concerns with careful chassis layout. I'd rather not have this project on a breadboard since I am NOT that confident in my ability to secure my workspace against the kind of voltages envolved.I'd rather transfer everything into a chassis. Also bear in mind there are further safety concern. Bleed resistors across capacitors are not a joke on this project. 1600v over 4700uf worth of capacitors in series demand for some serious calculations. Once I have 1. main b+ for output and drivers 2.secondary HV voltage for outputs (g2) 3. bias voltage for output ecc i can mess around with GU81m designs. This is not a project I think anyone can tackle by sticking things together. It's another "class" of amplifiers which demand specific technical solutions. My concern is to have some good feedback on aviable design. If we all agree one design can get things "rolling" I will build the amps. Once built and tested I will be sure to ask you all again for ways to increase performance (having done all necessary probing with my oscilloscope and meters). |
| High Voltage BjT's for Pre-driver stages of High Power Amplifier - Overview | tiefbassuebertr | Solid State | 38 | 30th May 2011 07:37 AM |
| Why high voltage Fets when low voltage types gives less distortion? | Circlomanen | Pass Labs | 21 | 9th December 2009 09:43 PM |
| Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. | kimbal | Tubes / Valves | 4 | 11th May 2009 08:05 PM |
| A high voltage drive fully differential driver/op amp | Russ White | Pass Labs | 21 | 18th July 2007 10:14 PM |
| gu81m | ik3ssj | Tubes / Valves | 4 | 4th March 2007 03:41 PM |
