| diyAudio Sponsor | ||
#2 |
Well I wouldn't consider this as a kit. It's just the PCB as far as I see. You don't need a PCB for such an "easy" amp. You can solder that point-to-point. That's the difference from a solid-state-amplifier where a good PCB layout is important. Furthermore, this isn't even a good layout. The space between the left EL84 and the caps is way too small. When that baby gets its 12W at the anode, the caps will die pretty soon. The schematic is nothing special and can be made by everyone with the slightest bit of theoretical knowledge. Not even feedback is applied which makes the pentode mode pretty useless.
Терпенье и труд все перетрут
#3 |
Thanks manta.
The pcb with parts including tubes and transformer is available as a "kit" from a DIY supplier and there is a note in the description that negative feedback can be implimented by changing two resistor values. I guess that the capacitor can be protected by some sort of a heat sheild. Not looking for "special" just compitent in that there is nothing outrageously wrong as I really like the small size and have ideas for a compact integrated. |
#4 |
I cant say anything about this board 'cause I did not see the price. I do know this, you can get a PP 6BQ5 PCB and parts from George (tubelab on this forum) for about $100 dollars.
#5 |
I don't see the board available on his web site.
#6 |
the board for the SPP is not on your web site and never been, but George commented that this design does not selling well, sure that there are still plenty of boards, those who have built only speak wonders about this design. |
#7 |
#8 | |
Best to buy a Tubelab design as it's designed by a real expert and will work beyond your expectations. Seriously, 'even' PCB layout requires expert thought for tube amps. |
#9 |
+1 again....
The SimpleSE was the first tube power amp I built and it still gets regular play in the rotation...for the following reasons I went with it... 1. Cost...you can go budget on this amp and have a nifty sounding amp 2. Support...plenty here 3. Relatively simple amp - low power so you will need highly efficient speakers - ideally something >90dB. 4. Excellent quality boards...I have soldered and unsoldered many different components and never have I lost a trace 5. Excellent intro into some of the theories of tube audio circuits. BTW...Mine is relatively hotrodded now with nice coupling caps, KT90 power tubes, and big *** OPT's...it can almost rival my EL84PP amp and sounds better for most music I listen to. |
| Williamson on EL84. Is it worth doing? | bae59 | Tubes / Valves | 11 | 28th May 2010 02:31 PM |
| ebay, 7c kit, worth it? | trigger | Tubes / Valves | 21 | 8th January 2010 01:38 PM |
| S-5 K-16LS Kit arrived in Germany !! | lufton | Tubes / Valves | 10 | 19th November 2008 10:59 PM |
| Gabe's PP EL84 amp kit, anyone? | bbaker6212 | Tubes / Valves | 0 | 26th August 2002 08:52 PM |
| Page generated in 0.10127 seconds (79.12% PHP - 20.88% MySQL) with 11 queries |
