diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   5 pin octal tube socket (http://www.diyaudio.com/forums/tubes-valves/204016-5-pin-octal-tube-socket.html)
Burnedfingers 8th January 2012 12:37 PM
tubesocket.jpg picture by burnedfingers - Photobucket
Help
I need a 5 pin version of the socket on the right for some adapters I want to make. So I need a 5 pin round type socket to fit in a 8 pin octal base. All I am finding is the 5 pin ceramic on the left which I do not want.
Kay Pirinha 8th January 2012 12:47 PM
why not just leaving the three pins you don't need unconnected? Or pulling 'em out of a stock socket? I think octal sockets with only five connectors are not available.
Best regards!
Burnedfingers 8th January 2012 12:50 PM
Look at the white socket and you will see the pin orientation is different otherwise I would have.
Kay Pirinha 8th January 2012 12:57 PM
As the international octal socket provides a 45 degree angle between all pins, you'll never find a version of it fitting into a UX5 socket with a 90-90-60-60-60 degree pin arrangement.
Best regards!
Burnedfingers 8th January 2012 01:03 PM
Well, I've had amplifiers in the past with round 5 pin sockets for the 807 tubes so there should be some out there.
dhaen 8th January 2012 01:08 PM
How about these?
5 Pin UX5 Amphenol Tube Socket British Made
Burnedfingers 8th January 2012 01:25 PM
I guess I can make them work.:) Thanks
pmillett 8th January 2012 01:33 PM
These?
http://www.leedsradio.com/images-soc...henol_78S5.JPG
Leeds Radio:
Leeds Radio - tube sockets
BTW, not "Octal"... "Medium 5-pin" or UY5 (sometimes incorrectly called UX5 - UX = 4).
Pete
Kay Pirinha 8th January 2012 04:34 PM
Well, Burnedfingers, if you'd asked for UX5 instead of octal sockets, it would have been much easier to understand you...
Best regards!
Burnedfingers 8th January 2012 09:23 PM
This is what I wrote in post #1. How could I be any clearer?
A 5 pin socket to fit in an 8 pin octal base.
Copyright 1999-2017 diyAudio
