diyAudio Sponsor
Old 17th September 2003, 01:53 PM   #1
Default Raven using Lundahl instead Sowter
I would like to build a PP line stage preamp..something like the Lynn Olson's Raven..but using Lundahl irons..
Anyone have some scheme to suggest me..? To send me?
It's not important the tube..not only 5687 like in the Raven..6sn7..6j5..e182cc..are welcome too..
I've not a big experience about..
Really thanks if anyone can send me some scheme..line +PSU..
Regards and greetings from Italy.
Maurizio
Old 17th September 2003, 03:06 PM   #2
Send a message via ICQ to Mikael Abdellah Send a message via MSN to Mikael Abdellah
Why do you NOT wan't to use Sowter? They are great!
Old 17th September 2003, 04:11 PM   #3
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Maurizio,
The LL1674 is excellent for this application (both as input phase splitter and output (amorphous cores ). I bought a Raleigh Audio PP kit from K&K audio that uses the LL1674.
Sounds sublime.
sowter 9050 or Lundahl LL1660 line out transformer? mwmitchell Tubes / Valves 13 20th March 2010 10:42 AM
2x Sowter 9545z bakus11 Swap Meet 4 16th November 2009 07:13 AM
Iron: Sowter, Lundahl, Magnequest tubesguy Swap Meet 5 7th June 2008 08:54 AM
Sowter 9055 wildmonkeysects Swap Meet 4 1st May 2008 02:30 AM
Sowter 5113 croccodillo Tubes / Valves 0 28th June 2007 12:40 PM
Page generated in 0.06757 seconds (69.17% PHP - 30.83% MySQL) with 11 queries
